10-12-2007, 06:27 AM
Re: The Alpha's cast iron front diff....
Originally Posted by Auggie Mathis
Yes the casting is the same its bolts right on. And i tried 4.56 gears
So where/how do you have a spare e-locker/differential laying around? Do you have both axles open right now?
10-12-2007, 03:06 PM
I work at the dealer so I can get any parts that i need . My son is out of town till Monday and i will take you a dam picture there is no BS here just trying to find a front locker. I cant find anything that works. The one that amstar uses was modified to the point that I cant justify the cost of it.
10-12-2007, 04:00 PM
Sorry, I just know someone who has used it. The rear Eaton in the front CI case.
So by how much does it not fit? And if they are both 4:56's it should work. If it is a tight fit, you could use a dye grinder to make "a little more room"?
10-13-2007, 01:10 AM
Now I just need to find a locker that will fit in there.
Maybe you'll be able to go to your Hummer Dealer and order one in the future.
10-13-2007, 08:25 AM
So... some say yep, it can be done and others say it can't hmmmm....
someone must know for certain  ... H3Builder - can you give me a definitive answer before I move hell and high water with the dealer to get me a cast iron casing?
Black Sheep Hummer Squadron - Arabian Gulf Chapter
I'm a Scot - the friendly race ...
10-13-2007, 04:34 PM
why dont you just ask the dealer if itll work, theyll be the ones who would probably know best about that one.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
10-14-2007, 12:09 AM
Now that's funny.
10-14-2007, 12:48 AM
10-14-2007, 12:49 AM
If everyone can just hold on, we will have the definitive for you in a couple of days.
10-14-2007, 01:34 AM
10-14-2007, 07:10 AM
Have a look at my posts and you'll get an idea about the "capabilities" of my dealer here....
 cool .......
10-14-2007, 10:03 PM
Originally Posted by Sewie
Yep.
Yep.
cool .......
Yep.
10-17-2007, 08:15 AM
... any news yet?
10-20-2007, 07:07 PM
BTT coz it's important... to me!!
Bebes, any news yet?
Cheers
JFF
11-12-2007, 10:19 PM
G'day guys,
Could anybody tell me if the differential carrier is swappable between the aluminium housing and the cast iron housing? (i.e., are they identical differential centers simply bolted into different housings?)
If anybody has some pics of the inside of the cast iron housing and of the carrier then we'd love to see them.
Also, in case anyone isn't aware, we have a model for the H3 rear.
Best regards,
-daniel
AIR LOCKER
dbongard@arb.com.au
11-13-2007, 06:55 PM
Time to get the cast iron diff and add the ARB for the front!
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
11-07-2008, 10:33 PM
Just giving everybody a update on my front locker.
I finally got the part numbers and and it fits on just fine. It is a eaton but totally different that the rear. I had to make a retainer to hold the wires in place.
The part number from gm is 25831502
11-07-2008, 11:49 PM
The 09 H3 adventures have a locker in the front just like the back. Should be pretty easy to retrofit one of these in to an older h3 with a switch and relay.
11-08-2008, 12:25 AM
I wish GM would offer a bolt-in cast iron locker package for our older H3's
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
11-08-2008, 02:48 AM
I used the locker that is for the front on a 09 modle .
