  #41
Old 10-31-2007, 05:11 AM
tower's Avatar
tower tower is offline
Default Re: Jet Stage 1 chip update
Stage 1 Jet Performance Module
This stage allows our customers, with stock or barely-modified vehicles, to use a performance module with less expensive, lower octane fuels (87 octane). With Stage 1, the programming is set to burn fuel at peak efficiency resulting in not only optimal performance, but gas savings as well.
Stage 2 Jet Performance Module
This stage is designed for those who are, what we call, "performance junkies"; these astute automotive enthusiasts have heavily modified cars and trucks. A "Stage 2" is for our really special customers who do use higher octane fuels (requires use of 91 octane or higher). A Stage 2 Performance Module features the most extensive programming to enhance horsepower to it's greatest potential and maximize torque. Fuel and timing curves are modified extensively for peak performance and drivability. This stage also requires the use of a 180 degree thermostat and free flow exhaust. An Aftermarket Air Intake System is highly recommended for a Stage 2 Performance Module.
Old 10-31-2007, 05:26 AM
I wonder what kind of results you can get if you use a Stage 2 on a stock H2 on premium gas?
Old 10-31-2007, 06:00 AM
tower's Avatar
WTH, I just bought one too. I trust the opinions of the people who liked them. And if it turns out to be a dud, DAJC and I can feel stupid together!
I think Elcova should get a kick-back from
PerformanceCenter.com
Old 11-02-2007, 02:10 AM
tower's Avatar
Got it today! Weekend install (probably). Can't wait!!
Old 11-02-2007, 03:20 AM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
I surely could use this with my s/c can't I?
dk
Darin Kaiser
Old 11-02-2007, 04:08 AM
tower's Avatar
Yes, but I would call to see if they recommend type I or II. That should be sweet!
Old 11-02-2007, 04:09 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Originally Posted by IRA51
Anyone in Phoenix running one of these ? with the heat, altitude,and ****ty gas we have here I wonder how it will preform ? add to that I have a black H2 and I wonder how the summer heat will affect the Jet chip .
Can't say anything about the Phoenix altitude...but as for a Black H2 in the Texas Heat (100 degrees or more with 100% humidity) my H2 runs great with the chip/volant.
Old 11-02-2007, 04:22 AM
Must be nice being local. Bastard.
I imagine mine will show up on Tuesday or Wednesday.
Old 11-02-2007, 04:38 AM
tower's Avatar
Doubt it. They said they sent me yours!
Old 11-02-2007, 05:40 PM
Dan D 2's Avatar
Dan D 2 Dan D 2 is offline
Dan D 2 is on a distinguished road
I installed mine the other night....had to tell how much difference it is. I usually drive with a light foot....Time will tell if there is any improvements in MPG's. I mainly bought it for towing puposes so I'll see this winter.
I know that the stock set-up had no problems towing my 6500lb boat but anything will help.
Old 11-06-2007, 01:42 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
dk
I would be very careful running either stage 1 or 2 with a supercharged set up, most of these will advance timing so that can be a problem...... however I have been told by a respectable tuner that GM typically has a pretty lean fuel trims in thier programs and that even though it sounds wierd he has gotten more power and better MPG's by fattening up the tables. If this chip tends to add more fuel you may be able to get away with it. Any case I would recommend contacting a reputable tuner or the manufacturer to make sure you dont have an issue with pre ignition or leaning out on boost.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 11-06-2007, 02:24 PM
TXSUT's Avatar
TXSUT TXSUT is offline
A generic, maybe even dumb, question: Why would you go with a chip such as the Jet instead of a programmer like Hypertech or Superchips? Is it just a matter of cost, or is there some other benefit? Just curious.
Thanks,
Pete
Old 11-07-2007, 02:06 PM
TXSUT's Avatar
Someone answer my phucking question!!!
Old 11-07-2007, 02:44 PM
MVR 155's Avatar
I wouldnt use any of these..... I would tune it with a program such as HP tuners since I have a friend that owns a speed shop along with a dyno and a guy that really knows his $hit when it comes to tuning.
NOW.... if I didnt know someone I would think going with a handhelp programmer would be ultimately better than just the chip since you can change shift points, compensate for bigger tires etc.......
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 11-07-2007, 03:07 PM
TXSUT's Avatar
Thanks MVR, you're a good man.
Old 11-07-2007, 10:25 PM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
I bought because it's "plug & play". Seems like half the people that go with the programmer have problems during installation and are always having to fk with it.
2008 H3 Alpha - Boulder Gray
Old 11-08-2007, 01:59 PM
TXSUT's Avatar
I haven't heard much on this forum about problems, and I have been completely satisfied with mine, but thanks for the response!
Old 11-09-2007, 04:20 AM
tower's Avatar
I went with the chip 'cause it was less expensive. If I had it to do over, I might go with the programmer. I haven't installed the chip yet. It's a little tough for a short fat cripple to reach the installation point. I think Hucky will help me put it in this weekend. The manufacturer says to take out the chip before you have the dealer tune it up. That sounds like a PITA so I guess I'll let the dealer pull and re-install it. That's where I think the programmer would be better, along with what MVR 155 said.
Old 11-09-2007, 05:50 PM
H2Finally's Avatar
X2 Haven't heard of anyone using the programmer being super happy of how the truck drives afterwords. Prob because most could not find the optimum setting to use. Many bought programmer to adjust for tires, or mileage, or to clear up errors. I drive on 37" tires, yet don't particularly care abt the speedo for the minute difference. Don't care about mileage either. Never have any problems with error codes. But am VERY HAPPY with the extra "oomph" this chip provides! Could not for the life of me understand why, if it's capable of such, GM won't program the H2 to drive like this from the factory! Me = MUCH happier camper!
Can BLING Get You Home?
Old 11-09-2007, 06:30 PM
Me likey chippy.
I blew away a Corvette Z06 the other day at the signal. It was all because of the chip.
That and the fact it was raining and he was spinning his tires like mad.
