Old 11-01-2007, 01:07 PM
NewHummerGuy's Avatar
Default Re: Got the Truxx leveling kit..but....
Originally Posted by YANKEES31
I am about 1/2 inch higher in the front. If I go ahead and get these shackles will the truck need another alignment?
I am amazed you can even notice a 1/2 inch variance just by looking at the truck.
Old 11-01-2007, 02:37 PM
YANKEES31's Avatar
YANKEES31 YANKEES31 is offline
YANKEES31 is on a distinguished road
It is pretty noticable
Jared
2007 H3X-MOTO METAL 951'S-TOYO 33x12.5 MT'S-MAGNAFLOW EXHAUST-TRUXX LEVELING KIT-PIONEER AVIC Z2-CARBON FIBER INTERIOR TRIM-REAL WHEELS HOOD DECK GRILL-NUMERIOUS OTHER CHROME ACCENTS
http://jaredneumann.tripod.com/index.html
Old 11-01-2007, 04:32 PM
Big Dad's Avatar
Big Dad Big Dad is offline
1/2 inch? Either crank it down or take it back and tell the install to crank it down for you.
Old 11-01-2007, 04:39 PM
H3slate's Avatar
H3slate H3slate is offline
You should maybe try turning down the torsion bars first, there is definitely nothing wrong with taking the bars back down a little.
When you adjust the torsion bars you should get an alignment, but adding the shackles should not reguire an alignment.
Thanks for the explanation Big Dad, if you are in the right neighborhood, you can get over a hundred trick or treaters, which makes for a busy night.
Yankees31, how about some pics and measurements of your truck?
Old 11-01-2007, 07:20 PM
sattv sattv is offline
sattv is on a distinguished road
My problem is ARE the fenders a good leveling point (they flex) I have been measuring from the frame to the ground maybe this is wrong? maybe not?
But who is to say the fenders are the same height on both sides?
Old 11-01-2007, 08:15 PM
Big Dad's Avatar
Exactly. What are the specs.
Old 11-01-2007, 08:58 PM
So should I purchase a Truxx kit or just extend the shocks and crank the bars?
Old 11-01-2007, 09:49 PM
Big Dad's Avatar
Well, I'm an educated man, private University type...the person you want to consult with is...CollegeSucks! JK!
Actually you'll want to do a forum search and figure that out on your own. There are many postings concerning the pros and cons of torsion bar and level kit.
You'll find that some fenders are at different heights which I equate to improperly cranked T bars. MHO.
Old 11-01-2007, 10:59 PM
Big Dad's Avatar
Sorry about being long winded...my fricken brain is drained.
Old 11-01-2007, 11:01 PM
YANKEES31's Avatar
Pic is a little blurry but you can see what I am talking about
Jared
Old 11-01-2007, 11:04 PM
Big Dad's Avatar
Dude man,
Throw a level on that driveway! That looks righteous!
Old 11-01-2007, 11:06 PM
Big Dad's Avatar
It looks like more than a half inch though. Is it an Adventure model?
Old 11-01-2007, 11:23 PM
YANKEES31's Avatar
No it is an "X"
So you think the shackles will right it?
Jared
Old 11-02-2007, 01:08 AM
Originally Posted by Big Dad
Wouldn't a "better" alternative to installing shackles be found in adding a leaf or having modified (I believe-arched) leaf springs installed?
How is an AAL any less "ghetto" than a shackle lift? And you'll likely end up with a crappy ride. Custom springs would be the best option for lifting the rear (aside from a SOA ) but would cost much more than either AAL or shackles.
Old 11-02-2007, 01:09 AM
Don't even mess with the rear yet. Just crank the t-bars down a couple turns.
Old 11-02-2007, 01:25 AM
YANKEES31's Avatar
Just curious why wouldnt you mess with the rear. I figured the easiest fix from what I read would be just to add the new shackles. If I bring the front down then another alignment will have to be done..right?
Jared
Old 11-02-2007, 04:32 AM
waynesoffroad's Avatar
waynesoffroad waynesoffroad is offline
waynesoffroad is on a distinguished road
The front end is not going to settle. The only time that it would settle is if you changed your torsion bars. If you have had your h3 for a while the springs are already settled. For the rear all you need is a set of Jeep YJ lift shackles. They are much cheaper and do the same thing. For you guys calling it Ghetto, What do you think your doing buy cranking the torsion bars up!
Old 11-02-2007, 05:24 AM
Big Dad's Avatar
I posed the question, e.g. "Wouldnt...."
But uh, let me get this straight...add a leaf is as ghetto as installing a shackle?
How so?
What about arching the springs? It don't cost that much. Is that ghetto also? If so, why?
What exactly do you mean by custom springs?
Lastly, SOA?
Thanks in advance.
Big Dad's Avatar
I didn't crank my "T" bars.
Old 11-02-2007, 02:15 PM
H3less's Avatar
H3less H3less is offline
H3less is off the scale
Just throw a 9000lb whinch on the front and she will be sitting pretty!
