Old 11-19-2007, 08:40 PM
pdxhummerguy's Avatar
pdxhummerguy pdxhummerguy is offline
pdxhummerguy is on a distinguished road
Default Any thoughts on this?
So I had my H1 in for service. It needed a new radiator and installation as well as a new turbo. My truck is a 2004. Dealer quoted my about $2500.00 installed for the new radiator and $3000.00 for a new turbo. Anyone have any thoughts on whether this seems a bit high.
Old 11-20-2007, 01:26 AM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Default Re: Any thoughts on this?
unless you can get it done under warenty, then those prices although high for any other vehicle, are what you can expect when you take it to a stealership to have work done. you may find that you get alot better satisfaction talking to a diesel technician. and much better prices. ar better still do it your self.
Old 11-20-2007, 05:45 PM
ssgharkness020147's Avatar
Having your turbo re-built at a good shop will run 600-800 (800 being a bit on the higher side). The replacement of a turbo is not too bad, just a PITA to get it out with the upper part over the manifold on. I think a stock radiator is around 1200 for the part, so the rest would be labor. IMO the prices are a bit high, but thats gonna be the norm at the dealer.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
