Old 11-21-2007, 05:30 AM
Default Is it warrenty
Right rear blinker works sometimes and sometimes it doesn't. Is it covered under warrenty? The 3 has about 27000 miles and is an 06.
Also would it be the bulb or the blinker relay ?
Most of my other cars/trucks/suv's in the past when it happened (same thing) fixed it ubder warrenty as long as it was in effect...
Old 11-21-2007, 06:56 AM
tower's Avatar
tower tower is offline
Default Re: Is it warrenty
NO. It's WARRANTY, and it should be covered as long as it's not the bulb. You can spring for a bulb, even if you can't spell.
Old 11-21-2007, 01:17 PM
~t
thank you
Old 11-21-2007, 05:55 PM
Big Dad's Avatar
Big Dad Big Dad is offline
Old 11-23-2007, 04:47 PM
its the bulb and it IS warrAnty ...
now the dam CD play is jammed... they have to take it out and send it somewhere else to extract the CD's and fix the unit...
BTW...Tahoe is a nice loaner...
Old 11-23-2007, 11:19 PM
sattv sattv is offline
sattv is on a distinguished road
what is body 5/40yhou
Old 11-23-2007, 11:40 PM
Old 11-29-2007, 02:37 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
At 27000 mi everything is till covered including bulbs. If they changed out the bulb and it works now, fine. but I have seen several loose bulb sockets that cause intermittant light problems on the h-3. If it happens again ask you dealer to check to sockets and/or add a little dialectric grease to the contacts.
Old 11-30-2007, 02:20 PM
tanks !!!
