12-04-2007, 06:13 AM
H3 air intake
Hey guy's I was wondering if the "pods" at the rear of the bonnet air conected to the Airbox or are they fake.
Cheers
Hoppy
12-04-2007, 07:35 AM
Re: H3 air intake
the one on drivers side left is fake i believe and the one on the passenger side right is the actual cold air inlet that connects directly to your airbox
(with insurance)
12-04-2007, 12:14 PM
Re: H3 air intake
Can this be confirmed
Hoppy
12-04-2007, 02:35 PM
Re: H3 air intake
Of course it can chaulkie, just look under your hood
12-04-2007, 09:51 PM
Re: H3 air intake
Negatory. They're both just for looks.
The intake is in the passenger side fender well.
12-04-2007, 10:24 PM
Re: H3 air intake
Fake
12-04-2007, 10:40 PM
Re: H3 air intake
Cheers
Hoppy
12-05-2007, 12:15 AM
Re: H3 air intake
which leads to that box. The passenger side box is vented on the bottom to receive air. The driver side one is closed off at the bottom and totally for looks.
12-05-2007, 02:33 AM
Re: H3 air intake
I just replaced the air box with a K&N kit. The stock box just has a tube that sticks into the fender well. It's not connected to anything. I have noticed that the air intakes at the rear of the fenders (back of the hood) have openings in the bottom. That must feed somewhere. Does it feed to the passenger compartment?
2007 H3 Lux/Adv 5 speed, Gibson Extreme Duals cat-back, K&N FIPK, PCMforless tune, SAW torsion bars, Samco Shackles, Fox Racing shocks, Trail Duty Bump Stops, 35" ProComp Xterrain tires w/Tactical Rims, Gobi Stealth Rack
12-05-2007, 03:41 AM
Re: H3 air intake
A can of worms has opened
Investagating time
Hoppy
12-05-2007, 02:07 PM
Re: H3 air intake
take it back and get a refund, it won't do anything for you !!!
12-05-2007, 03:50 PM
Re: H3 air intake
Does the size of the intake matter? Frenzy?
12-05-2007, 08:32 PM
Re: H3 air intake
 Show me the tube that leads from that vent cap to the airbox.
The holes in the vent cap are there to allow airflow through the engine compartment. As I said before. the air intake, which leads to the airbox, is in the passenger side fenderwell.
12-05-2007, 09:02 PM
Re: H3 air intake
Sewie is right. Those puppies are all for show...
You could run a tube down to the inner fender plenum. Not certain it would do anything
12-07-2007, 10:25 AM
Re: H3 air intake
Really, have you done a dyno? I've heard reports of dyno's that dont support your statment and my experiances greatly differ from your statement. Shouldn't make statements like that unless you have proof.
12-07-2007, 07:29 PM
Re: H3 air intake
I suggest you do a good search of this forum...
the H-3 comes with a Cold Air Intake that DOES NOT require oil on the filter element...I believe that (not 100% sure) almost all the aftermarket cold air intakes require you to oil their element which increases the chance of contaminates residue (oil) getting where it DON'T belong...
you would be much better putting that $200 to $400 towards a better exhaust system...
Again do a complete search of THIS FORUM before responding (please)
12-08-2007, 12:28 AM
Re: H3 air intake
I've had several K&N FIPK's before, they all have made an improvement. As this one has. If you don't over oil the filter, there is no problem. Not everyone likes the K&N, to each his/her own. No need to get beligerent.
I have noticed a small increase in power, which I expected. I didn't expect a large increase in noise though. At WOT and over 4k rpm's, the truck gets very loud. I have noticed a noise increase with each FIPK I've done (that makes sense) but this one is a lot. Still, it's worth it. And I've already done the cat-back and program. I'll do the header as soon as that comes out also.
12-08-2007, 10:02 PM
Re: H3 air intake
Wow, you didn't even respond to my statement, or address my challenge on yours. You said "it won't do anything for you" which I have seen reported dyno test that do not support that statement. Then in your next post you challenge my post with a completely different aspect of air intakes.
It is pretty obviouse there is restriction on the factory air intake system whether it be cold air or not(yeah, I knew it was a cold air type already  ). Just look at the fitting from the fender to the air box and then the tube going to the throttle body. They are not the same size. Then put on a KnN replacement and drive around a bit. The try driving with the top of the air box removed. Tell me you dont feel more throttle response and less downshifting when climbing hills.
I don't think I need to search the forums as Ive read most of the interesting and helpfull tech sections here and many other places
12-08-2007, 10:40 PM
Re: H3 air intake
It is pretty obviouse there is restriction on the factory air intake system whether it be cold air or not(yeah, I knew it was a cold air type already  ). Just look at the fitting from the fender to the air box and then the tube going to the throttle body. They are not the same size. Then put on a KnN replacement and drive around a bit. The trty driving with the top of the air box removed. Tell me you dont feel more throttle response and less downshifting when climbing hills.
OK,
What were your findings? Empirical data only kindly...
12-08-2007, 11:52 PM
Re: H3 air intake
Did somebody mention air ducts for show?????
Yellow Lux H3, w/Adventure Pkg, Borla, K&N.
