Old 12-14-2007, 10:01 PM
jmsspratlin's Avatar
Unhappy Storing an H2
Soon I will be deploying and I will need to set the H2 up for about 6 months. Wondering what all I should do as far as gas stabil, putting the truck on stands to eliminate the possibility of flat spots in these expensive tires, and any other things. Thanks....Jamie
Old 12-14-2007, 10:48 PM
porschett's Avatar
Default Re: Storing an H2
Get a battery maintainer, easier than disconnecting and keeps you from having to reset everything. My Porsches sit for months at a time. I park them on 2' x 2' squares of plush carpeting. Never have had a problem with flat spotting. As far as the gas, a stabilizer wouldn't hurt, but be sure to fill up the tank to avoid moisture build-up.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 12-14-2007, 10:58 PM
Yetti Yetti is offline
you can put it on Jackstands, that will save on tires & bearings. the second thing would be change the oil, put in fresh engine oil. if its sitting a long time it can draw in mositure. when you get back first thing would be to pop the plug and see if theres water pooled by the drain plug. if so drain and refil. same goes for any stored vehicles. the fuel will go bad , but the tank is vented and will draw mositure. if the tank is full the air space in the tank is reduced and the amount of air being exchanged is less as the tank is heated and cooled during the changes in weather & heat/cold cycles. the Sta-ble in the fuel will help to keep it from breaking down as fast. use dry gas to break up any water when re-activating the system if you suspect it may have water in it. if by chance your storage space has moisture in it then I suggest a non powered humidifier. use a bag of rocksalt(in a burlap sack or its equal) hanging from the ceiling. use a barrel or bucket depending on how moist the air is. we used to keep our basement dry by hanging one over the floor drain. it would drip constantly. for some reason the air sticks to the salt if it has moisture in it. put the rig in a corner away from your car and it will be fine. you can even route it out a drain to the outside if you think it will over flow or nobody will be around to check on it regular.
by the way take out the battery. set it on a board(wood) and get a r/v charger to save it from going flat. I use a 250 milli amp and it clicks on when it sees a need. the reason I say to take it out is to prevent accidents. I have had batteries explode while being stored. one blew up and sent acid everywhere. I didn't find it for days, to say the least I had a mess & damage to clean up.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 12-15-2007, 12:21 AM
tower's Avatar
tower tower is offline
Just ship it to So Cal. I'll make sure your battery doesn't go dead. Be safe over there, Jamie! Hopefully the Dems will bring our troops home before you ship out!
Old 12-15-2007, 03:30 AM
Sportsdude's Avatar
Sportsdude Sportsdude is offline
Sportsdude is off the scale
I didn't do anything special to mine but did fill up the gas tank. Oil changed when I returned.
Old 12-15-2007, 05:34 AM
Doubt that they'll pull out before I leave. Unless Christ comes in the next few weeks, I'm headed out. Thanks....Jamie
Old 12-15-2007, 05:49 AM
tower's Avatar
It is almost Christmas!
Old 12-15-2007, 06:50 AM
3Hummer's Avatar
3Hummer 3Hummer is offline
my friends gettin sent out in may hes in the air force, im hoping teyll pull out before then, but this kid actually wants to go over there! crazy! what division of the military are you in? and whats your job in it?
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 12-15-2007, 01:49 PM
mikejr's Avatar
mikejr mikejr is offline
Jamie - our thoughts and prayers will be with you for a safe return.
Thank you for keeping my family and our country safe! If you can, keep in touch with the forum.
2009 H2 Silver Ice LE
Old 12-15-2007, 03:16 PM
USAF, Critical Care Nurse..........yeah....another focker
Old 12-15-2007, 03:18 PM
Thank you, I will try to stay in touch, however communicating with the family will be my first priority.
Old 12-15-2007, 03:42 PM
STAY SAFE BRO ! GOD BLESS YOU !
Old 12-16-2007, 02:10 AM
Thanks to you all, still have a few more weeks though to pester you guys and put up multiple repost.
Old 12-16-2007, 03:26 AM
mikejr's Avatar
as well it should be. Keep your head down and stay safe buddy.
Old 12-16-2007, 03:46 AM
Badace's Avatar
Badace Badace is offline
Badace is on a distinguished road
Good Luck Man. Keep sane. I pray the Dems don't screw up the funding. They need the money from the war to keep the deadbeats into Ripple and mad dog.
Old 12-16-2007, 05:38 AM
3Hummer's Avatar
man you must see some crazy wounds with that job.
2017 VW Jetta S
/''T''|[___|___]
Old 12-16-2007, 05:59 AM
Mr. I - Man's Avatar
Stay safe bro!
