Old 01-06-2008, 02:37 AM
dlinden200's Avatar
dlinden200 dlinden200 is offline
dlinden200 is on a distinguished road
Default Tiny hole in Catalytic converter
Was letting the 2006 H3 warm up, it was 5 degres, and I noticed exhaust coming from the middle of the H3.
I crawled under. There is a tiny hole in the middle of the catalytic converter.
It is NOT a rust hole. Looks like a 1/8th drill bit size.
I am assuming this is normal. Anybody else notice thge hole?
Old 01-06-2008, 02:51 AM
D-MAX's Avatar
D-MAX D-MAX is offline
D-MAX is on a distinguished road
Default Re: Tiny hole in Catalytic converter
I think someone drilled it, i've heard of this. do you have any enemies?
2007 h3x
2006 GMC 2500HD DURAMAX
Old 01-06-2008, 04:03 AM
can't tell, it never gets that cold here...
Old 01-06-2008, 07:01 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Sure its not the muffler or the resonator as they both have drain holes for moisture. Cat should have no holes.
Old 01-06-2008, 12:51 PM
Mine drips condensation, sometimes blackish water during warm up thru hole in muffler/resonator...
Old 01-06-2008, 03:57 PM
2xtreme's Avatar
2xtreme 2xtreme is offline
2xtreme is off the scale
same here
Old 01-08-2008, 03:18 PM
pdsq99f4 pdsq99f4 is offline
Normal, it is supposed to be there to drain the water. You're probably seeing the resonator and not the cat.
