Old 01-06-2008, 08:11 PM
csdriver8 csdriver8 is offline
csdriver8 is on a distinguished road
Default My H3 Rear window washer fluid
Nothing comes out any more but the fluid is fine with the front windshield. What's the problem? Is thier a seperate refill for washer fluid for the back window????
Old 01-06-2008, 08:48 PM
Default Re: My H3 Rear window washer fluid
line is clogged
Old 01-07-2008, 12:53 AM
HummerHippy's Avatar
i believe rear fluid comes from same place as front.
29-Jul-2008
Old 01-07-2008, 02:51 AM
3Hummer's Avatar
3Hummer 3Hummer is offline
Mine was the same way. I ran out of fluid so i replaced a little bit of it nothing came out of the back, i took it to the dealer to get an oil change and they topped off my fluids and then bam my rear windshield fluid worked still dont know but felt that id share that with you.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 01-08-2008, 04:16 PM
pdsq99f4 pdsq99f4 is offline
If you have an early 06 and never had the recall done take it to the dealer. There was an updated pump for the rear washer. The recall ended a year ago but if you're still under warranty, it'll be covered.
Old 01-08-2008, 11:34 PM
H3NCO's Avatar
H3NCO H3NCO is offline
H3NCO is on a distinguished road
I know there was a bit of a learning curve with mine as well. If the level is below a certain point it will not feed the rear window washer fluid line. The front will still work as there is fluid in the reservoir. Top it off and all should be fine. If not, do as others suggested and check for a clogged line or other issue.
