Old 01-09-2008, 07:50 AM
southpaw26 southpaw26 is offline
southpaw26 is on a distinguished road
Question Power Folding Mirrors Will Not Work?????
Hello. I own a 2004 Hummer H2. And I just figured out the other day that my power folding mirrors are not working. I have read many threads on here regarding this but I am still real fuzzy on it. You see the thing with mine is that neither mirror will even attempt to fold in. Both power mirrors are working fine when it comes to adjusting the mirror glass though. When I place my mirror selector in the middle and hold down the toggle to fold them in all that happens is the mirror glass itself will adjust, but neither mirror even attempts to move inward. I have even held my hand on the outside of the mirror bracket to see if I can hear or feel any type of vibration, noise or movement, but again I still get nothing. Is it possible that maybe I have a blown fuse or something, or is it maybe possible that the connections to the mirror may have some corrosion on them and it is not making good contact. If anybody out there can shed some light on this for me I would appreciate it greatly! Thanks!!!!!!!
Old 01-09-2008, 01:33 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Default Re: Power Folding Mirrors Will Not Work?????
Originally Posted by southpaw26
...hold down the toggle...
Are you pressing down on the right-side edge of the button? It should be a one-touch affair, without having to hold it down. That said, the pre-2006 mirrors are plagued with gremlins. My passenger side (2005) has finally given up the ghost and needs replacing.
Old 01-09-2008, 02:25 PM
working Hummer's Avatar
Mine did that on my 03, it's a common problem in the old style mirrors. Assuming your pushing the button correctly, your either going to have to tear it apart (search old thread to find out how) or just replace them like I did with the new style. "thanks extended warranty!"
Old 01-09-2008, 03:13 PM
This is very old and there are quite a few threads on this that can be found using the "Search" function.
Basically, it involves manually folding the mirrors in and out, then cycling them through 3 times with the button.
By searching, you'll also find the TSB on this issue, however I'm not sure dealers are still replacing them under warranty. That info may be in one of the old threads.
Old 01-09-2008, 06:25 PM
i have driven the H2's since they have been out and have yet to NEED to power fold the mirrors.....what are you guys doing that they need this much attention......
Old 01-09-2008, 10:06 PM
What? you don't fold them in while driving? I get better Mpg due to the better aerodinamics. Plus who needs them out to see, just swerve lane to lane and people will move.
Old 01-09-2008, 10:17 PM
Old 01-09-2008, 11:00 PM
porschett's Avatar
Need as much space as possible in the garage, my wife thinks her 600SL is as big as a H2: !!!!!!!!!!!!!!!!!!!!!!!!!!!
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 01-10-2008, 12:43 AM
Actually the reason that I need them to work is that the other day when I had the hummer cleaned up my detail guy manually pushed in my driver side mirror, and now it is loose and will vibrate some while driving down the road. Apparently the only way to make it regain its tension is through power folding sequence. And like I originally said I searched the forum and there are many threads on this issue but I hove not seen one where someone had a situation where both mirrors would not even respond or do anything.
Old 01-10-2008, 02:18 AM
Southpaw,
I have an 03 and both of mine are dead as well. I went to a MD football game and when the mates unloaded, one guy on each side pushed each mirror b/c the lot was tight.
Both have been dead since. I have tried the manual reset that was mentioned above and in previous posts, but to no avail.
I need to get new ones, but my warranty is long since gone (I didn't get the extended warranty )
Lemme know what you end up doing.
-Matt
06 - Black Caddy SRX
Old 01-10-2008, 06:43 PM
You must have an 03-05 because the mirrors on the 06+ were changed and the earlier ones under warranty had the mirrors replaced with the 06 mirrors.
The "search" feature will help you tremendously.
Old 01-10-2008, 07:12 PM
I have seen mirrors on ebay for pretty cheap , bids starting at around 40$$$ they run around 600 new i think
