Old 01-19-2008, 02:19 AM
cow boy cow boy is offline
cow boy is off the scale
Default 4 ton H2
I weigh my H2 at 2 different scale and the average was 4.6 tons, at 2,000 lb. a ton that = 9,200 lbs. thats more than a ton and 1/2 over a stock H2 ( 6,400 lb)
winch (wire cable)
Duramax/ Allison
ladder/roof rack
fuel tank- full
5gl. jery can full
spare tire
4- 3 piece rims
and me in the truck
The point is thats too heavy, everything adds up. The Allison 5 speed trans. is worth the extra weigh. In tow haul going down hill it will down shift to slow U down. The truck has enough power to pull out 2 small trucks stuck in the mud. I would not take my H2 into a mud hole it would sink so deep I would have to call a backhoe to get out the 9.5k winch with a block will not over come the suction of the mud. In the sand with the tire psi down it feels like it is going to dig in. Its a great recovery vehicle and can tow a heavy trailer with ease. The weigh difference between a diesel and a gas eng. is a lot!!
Old 01-19-2008, 02:27 AM
lonePalm's Avatar
lonePalm lonePalm is offline
lonePalm is on a distinguished road
Default Re: 4 ton H2
wow!!! Thats a big difference
Drive fast and Beep the horn!
Old 01-19-2008, 02:54 AM
tomp's Avatar
tomp tomp is offline
How long do your wheel bearings last?
Old 01-19-2008, 02:55 AM
That is one nice rig you have!!!!!!!
Old 01-19-2008, 03:00 AM
I'd replace those stock tierods. With all that power and weight you'll snap one at somepoint.
Nice looking rig.
Old 01-19-2008, 03:15 AM
I have been wanting to put the stronger tie rods on and use the old ones for spares .
Old 01-19-2008, 04:23 PM
Same here. I'm at almost 5 ton with all the plastic to steel conversions.
Steel bumpers
Steel skid plate
Steel wheels
Steel guards
Old 01-19-2008, 04:34 PM
Old 01-19-2008, 06:42 PM
Originally Posted by Agriv8r
9mpg too, Baby!
Old 01-19-2008, 08:11 PM
ADAMA in co . I was wandering how low due U run your tire psi with all that weight, I have been not airing down as much because of my over weight.
Old 01-20-2008, 02:48 AM
ssgharkness020147's Avatar
You should have seen the look on the drivers face when I lifted a tow trucks front tires off the ground while be unloaded once. We figure I'm a minimum 10.5K (the tow truck was rated the haul 9K).
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 01-20-2008, 03:45 AM
Pics of the owners of these 4 ton H2s.
I'm working on a hunch here.
Old 01-20-2008, 04:22 PM
I assume you mean off road. There would be no reason to adjust down on the pavement. In fact, I go up on the pavement. I would say 45-50 on and 18-20 off road. The tires are 37s though.
Old 01-20-2008, 07:39 PM
HAHA!!! Giggity!!!
