02-10-2008, 02:01 PM
Electric HUMMER
Sunday, February 10, 2008
Now a Hummer EV
fficially Licensed Design...The HUMMER? H3? is the first proportionally correct and only Licensed custom Estate/Golf Car styled after the H3? HUMMER?. It includes standard features such as 15 inch custom built and proportioned HUMMER? wheels, rugged all aluminum I-beam chassis, Genuine HUMMER? Chrome grill, standard equipment includes functional headlights, tail lights, turn signals and fog lights. Patent Pending 180 degree tailgate. The all new HUMMER? H3? Estate/Golf Car is the new industry standard for custom luxury electric vehicles.
Unmatched Engineering...
Engineered to be the best custom luxury electric vehicle, the HUMMER? H3? was designed on a rugged all aluminum I-beam chassis. It boasts the roomiest seating area and the most legroom of any other Custom Electric Vehicle in the world. The interior is ergonomically designed with cup holders in the center console, and all of the controls and switches right at your fingertips. The HUMMER? H3? Estate/Golf Car uses a long range 48-volt system to ensure maximum range while delivering optimal power to the high torque motor. The HUMMER? H3? Estate/Golf Car also features the highest quality components available for the Electric Golf vehicle industry. It comes with a programmable Alltrax, Inc. 4844 Electronic speed controller, a front wheel hydraulic disk brake system that is coupled with a fully self adjusting rear drum brake system, an onboard DeltaQ Technologies IntelliQ computer controlled charging system so that you can drive and charge your car anywhere there is an available power outlet, and industry leading Trojan T-875 batteries which are all standard features. For added usability, the car is equipped with an onboard 48volt to 12volt converter giving you a 12volt power outlet right on the dash to charge your cell phone or provide power for your laptop so that you can stay in touch with the world while you are on the course. As standard safety enhancements the HUMMER? H3? Estate/Golf Car is outfitted with working headlights, brake lights, turn signal lights, a working horn, reverse warning buzzer and a standard 4 wheel braking system.
Delta-Q IntelliQ-Q on-board Charging System.
Trojan T-875 Batteries
Hi-speed, Extended Range
In-Dash 12-volt Power Source In-Dash
Forward-Neutral-Reverse
Golf Bag Attachment
02-10-2008, 03:31 PM
Re: Electric HUMMER
whats one of those cost?...I bet an easy 20 grand.
2009 H2 Silver Ice LE
