02-13-2008, 05:54 AM
Which synthetic winch line?
Ok, my steel line is all frayed and smashed etc. It is starting to get scary when using it! I am going to switch over to a synthetic cable. My winch is the H2 Multi-mount 9.5ti. What size 3/8" right? And what brand? Are any colors better or worse due to UV rays? It will sit outside much of the time. I heard you should switch to an aluminium fairlead as well. Is this true?
Thanks.
02-13-2008, 07:45 AM
Re: Which synthetic winch line?
105' of Amsteel. Make sure to use an aluminum Haas fairlead.
02-13-2008, 04:32 PM
Thanks what kind of termination do you recommend? 3/8" right?
02-13-2008, 10:53 PM
Blue..
02-14-2008, 05:28 AM
02-16-2008, 05:55 AM
I ordered the 125ft of 3/8" Viking combo line: 25 ft of the fire line so I dont have to worry about the line melting to my roller, and the rest Am-steel blue w/ the safety thimble on the end.
All from winchline.com
I'll take some pics once its installed.
02-27-2008, 09:01 PM
This AmSteel line is the way to go! I was able to barely fit 125FT of the 3/8" line on my Warn Multi Mount. Its so much easier to deal with and saves 27 lbs over the steel cable. Also the safety thimble keeps your fingers a bit safer (you dont have to hook to the handle anymore)
