  #41
Old 04-16-2007, 08:20 AM
TA8088 TA8088 is offline
TA8088 is off the scale
Default Re: Extended Shackles
Originally Posted by TANDREW
sits level front raised using leveling kit and rear shackels
Looks good. Where did you get your shackles from? Custom made? Which leveling kit are you using?
Old 04-16-2007, 11:15 PM
TANDREW's Avatar
TANDREW TANDREW is offline
TANDREW is off the scale
Had the work done by Tire Pros / Big Johns performance. I had a leveling kit from ORU/Off Road Unlimeted installed and Bilstein shocks. They told me the shackles are the same as they use on the Jeep.
Old 04-16-2007, 11:24 PM
Can you get us a part #???
Old 02-27-2008, 06:49 PM
BTT
Old 02-29-2008, 05:01 AM
They look like the gold Warrior shackles (same as I have, but mine are grey).
FITS LIFT FRONT GRAY FRONT GOLD REAR GRAY REAR GOLD
'87-'96 YJ Wrangler 0" WAR120 WAR320 WAR122 WAR322
'87-'96 YJ Wrangler 1/2" WAR149 WAR349 WAR150 WAR350
'87 -'96 YJ Wrangler 1 1/4" WAR114 WAR314 WAR123 WAR323
I got the 1 1/4" lift ones.
Old 03-11-2008, 11:58 PM
Sewie,
Are you satisfied with your shackles.
Would you recommend them?
Old 03-12-2008, 07:32 AM
Yes.
Old 03-12-2008, 05:03 PM
Thanks Sewie,
Those shackles look strong. Just contacted them to see what they have for a application to a relatively stock H3 shackle lift without any add ons. They said they dont support Hummers...
It looks like they have a product that gives a 1/2" lift similar to what you used to get the 1.25". item WAR150
Do you think that shackle could be used without some of the bells and whistles needed to get the big lift?
W
Old 03-13-2008, 04:26 AM
Originally Posted by wpage
Those shackles look strong. They are. Much beefier than stock. One of my stock ones actually bent. Just contacted them to see what they have for a application to a relatively stock H3 shackle lift without any add ons. They said they dont support Hummers...
W
Not sure what you're asking there.
Old 03-13-2008, 11:18 AM
Sewie,
What I want to find out is how far can a shackle lift go B4 any stock mods are required...
Like extending shocks
extending brake lines
Seen shacles offerd that give anywhere from 1/2" lift at the rear bumper to several inches. Trying to understand what can be added without changing anything off but the stock shackle.
Thx
Old 03-13-2008, 08:03 PM
The stock shocks don't have much travel to begin with, so I would consider new shocks after even a 1" lift. Just be sure to also check the compressed length so they don't bottom out. The stock shocks and swaybar links should be fine with 1/2" lift. Bebe is running the Samco shackles (3/4" lift) with the Fox shocks with no problems.
With what I've done, the brake lines may need to be lengthened but I haven't done it yet. There is a bit of play in them at stock height.
From what I've read, anything beyond 2" of lift and you need to start worrying about things like pinion angle.
Old 03-14-2008, 01:19 PM
Sewie,
Thanks for that. Going to take your advice. Will post pic's when complete!
W
