Old 04-21-2008, 10:57 PM
moorec614 moorec614 is offline
moorec614 is on a distinguished road
Default Are the door's water proof?
As far as crossing water deeper than the rocker panel, are the doors sealed water tight?
In other words, if I get water above the lowest part of the door, is it going to come in?
Old 04-21-2008, 11:05 PM
Default Re: Are the door's water proof?
You should be fine as long as you keep moving. I've done a couple crossings with water up to the headlights and never had a drop enter the cabin.
Old 04-22-2008, 01:20 AM
same here. NEver had an issue..but was moving..not stopped.
Old 04-22-2008, 03:35 AM
Big Dad's Avatar
Big Dad Big Dad is offline
Ever seen this one?
It's from a thread, I don't remember who, but it seemed to be a keeper!
I'd most likely ask the owner of this one:
Old 04-22-2008, 03:36 AM
[quote=Big Dad]Ever seen this one?
ONLY THE YELLOW ONES ARE WATERPROOF !!!!!
Old 04-22-2008, 06:47 AM
tomp's Avatar
tomp tomp is offline
H2s are water-tight for the most part. H3s will leak. I have both 2 & 3 so no bashing stems from this post.
Old 04-22-2008, 02:42 PM
blindzebra's Avatar
I'm on my 2nd 3 and I've only had the most minor of leakeage and that was due to having dirt in between my door seal and body. When my seals are clean, they've never leaked a drop. The h3's doors are triple sealed for reason, so as long as you keep them clean you should be fine
Old 04-22-2008, 05:37 PM
Tomp, can you please elaborate on your experience?
Old 04-22-2008, 05:43 PM
..spilled his beer?
Old 04-22-2008, 06:55 PM
Big Dad's Avatar
...peed in his pants while wheeling?
Old 04-22-2008, 11:13 PM
BigPoppa1411's Avatar
Old 04-23-2008, 04:26 AM
tomp's Avatar
Wasn't the beer or the pee
The H3 door seals don't keep the water out. Granted it comes in slow enough to drive through water for a short period, but they "will" leak. The H2 seals seem to do better.
Old 04-23-2008, 05:07 AM
H3slate's Avatar
H3slate H3slate is offline
Wheres the captain when you need him? There was a thread about a year ago from the "Captain of the Titanic" talking about how he got stuck with water half way up the door on one side and about the water coming in the cab. Of course no pics were produced and his story seemed to keep changing, but I would not bet money on your doors being water tight.
Found it; http://www.elcovaforums.com/forums/s...ad.php?t=19608
Of course, I have enjoyed going through some deep puddles (close to grill level) and have had no problems with leakage.
Old 04-23-2008, 05:11 PM
Big Dad's Avatar
Holy $hit!
I've read that one before and it still makes me laugh so hard I just about wet myself!
Old 04-24-2008, 01:48 AM
These conflicting answers are pissing me off.
Whether I come out with more respect for my H3, or soaked carpets, I'm going to find out for myself.
Pics to follow in the coming weeks.
Old 04-24-2008, 01:56 AM
H3slate's Avatar
As long as you don't stop you will be fine. Keep the water below or around the headlights. If you stop the water will come in past the door seals.
Don't forget the towels!
Old 04-24-2008, 02:43 AM
Crash ?'s Avatar
Crash ? Crash ? is offline
You stop and you're swamped.. I've soaked the carpets twice.. Once up front and once in the rear.. The back door/hatch however does seem pretty tight though.. That was well under when I had water come in the rear passenger door..
Rob
Old 05-05-2008, 03:41 AM
chizel chizel is offline
chizel is off the scale
Had about 5 inches of swamp water in mine this weekend. Ended up getting framed in this hole and it wasn't for about 10 minutes till I got pulled out. Boots were floating and I got water in my transmission. Fluid was a bright pink and transmission wouldn't shift into third. OnStar worked great.
Old 05-06-2008, 12:10 AM
How does water enter the transmission?
Old 05-07-2008, 11:06 PM
Not a clue. I guess their is supposed to be a one way valve in the vent but it didnt work. Haven't got an update yet on exactly what happened to it yet.
