06-01-2008, 04:45 AM
H2 top speed?
Hello,
I purchased my '03 H2 a few months ago. It tops out (speed) at around 80-85 mph. Is that about what other 03's do? Thanks.
06-01-2008, 05:21 AM
Re: H2 top speed?
105mph
06-01-2008, 05:22 AM
Re: H2 top speed?
162
06-01-2008, 05:27 AM
Re: H2 top speed?
Originally Posted by Hyperspud
Hello,
Ours will do 100+
~Richard
06-01-2008, 05:55 AM
Re: H2 top speed?
DRTYFN and I averaged 90-100 on our way to Moab.
06-01-2008, 09:41 AM
Re: H2 top speed?
Same my 03 will go over 100. Maybe yours has the speed govenor in still?
06-01-2008, 04:54 PM
Re: H2 top speed?
Thanks everyone. I figured something wasn't right. The motor runs smooth and doesn't seem to "miss". I didn't realize there was a governor. Thanks Again!
06-02-2008, 02:31 AM
Re: H2 top speed?
There actually is not a governor but there is a top speed control built in to your computer that controls your motor, transmission, speedometer, etc. Unless you go to the dealership, you'll have to buy a programmer to access the computer and tell it to allow higher top speeds. 80 to 85 sounds low unless you have after market tires that are larger, causing the computer to go out of whack.
If the tires are larger, then the computer needs to be reprogrammed with a programmer, to make the changes. The programmer is a small handheld device that plugs into your vehicle under the dash, very simply. I use the Diablo Predator, but there are others available.
Hope this helps. Good luck.
06-02-2008, 03:18 AM
Re: H2 top speed?
Thanks Gunzz,
I have the stock wheels. Right now the debate is to either take my rig to the dealer to see if there is something else wrong that would inhibit top speed or save the money from not seeing the dealer and buying a programmer to adjust accordingly. I'm just starting to investigate programmers.
PS. I like your ahhh.........picture! Thanks Again!
06-02-2008, 08:32 PM
Re: H2 top speed?
Thats it, electronically controlled not a govenor, only heeps use those old govenors  , but yea your rig should hit 100+ like pie unless your resticted by the computer.
06-02-2008, 08:36 PM
Re: H2 top speed?
105ish....or so im told....wait, i dont have to say that anymore....definately 105 in 05, 06, 07, 08.....
06-02-2008, 11:08 PM
Re: H2 top speed?
I have had it right up to the 100MPH mark, definately seemed like it had some more left, cruising at 90-95 is no problem at all. You should be able to do 85 or better without hitting a wall
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
06-03-2008, 02:59 AM
Re: H2 top speed?
OP here. i brought my H2 in today and was told my catalytic converter was plugged...explaining the power loss. I'm lookin' forward to driving it when repaired. thanks to all the posters.
HYPERSPUD
06-05-2008, 11:14 AM
Re: H2 top speed?
You should go ahead and get programer. It will still unlock so much power and torque you will be amazed. It gives you control of so much like adjusting your wheel size in the computer to match what you are running so speedo is accurate.
TAZ
06-06-2008, 09:21 AM
Re: H2 top speed?
Mind used to do around 100 mph when i got it .
With a Little of magic
It went a round 125 mph to 130 mph depends where the wind blows
This is a video hope it helps ?
http://www.youtube.com/watch?v=Jc1xULbMvx0
2009 H2 SUT Stock !
2006 H1 Alfa Wagon not stock
Can't wait to fix on some parts on it
06-06-2008, 10:31 AM
Re: H2 top speed?
