Old 09-29-2004, 12:26 AM
HUMMERDOGG HUMMERDOGG is offline
HUMMERDOGG is an unknown quantity at this point
I have started getting the LEFT REAR DOOR AJAR notice on my driver information location above the steering wheel. The problem is, the door ain't ajar... My H2 is a 2003. I know Ed G. posted this same issue back in June but no one ever came back to him. The suggestion was to take it to the dealership.
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=130101486 &r=130101486#130101486
Anyways, has anyone had this problem, and if so, how'd you solve it? I really hate going to the dealership since I'll see the 2004 Black Diamond H1 Wagon there that they want me to buy, and that I want to buy, but that I can't afford to buy yet...
Damn...
-HUMMERDOGG
Damn...
-HUMMERDOGG
Damn...
-HUMMERDOGG
Old 09-29-2004, 01:56 AM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
HUMMERDOGG,
When I took my H2 to the dealership with the "right rear door ajar" they ended up replacing the BCM. They first tried replacing the door actuator switch because they had repaired an H2 with the "left rear door ajar" message by doing so. Call McGinnis on I-10 they'll get you fixed.
Ed
2008 H3 Alpha - Boulder Gray
Old 09-29-2004, 02:04 AM
Ed.G-
Thanks for responding... I actually bought mine from McGinnis and will give them a call tomorrow telling them what it's doing.
Hopefully, it doesn't take too long to fix...
-HUMMERDOGG
Old 09-29-2004, 03:27 AM
Ed G.'s Avatar
Good Luck!
Old 09-29-2004, 11:13 AM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=857104287
Just finished with Right rear door Ajar. Took 2 weeks to fix replaced door switch. Stripped all wires and traced for shorts. Then they replaced the BCM, just like I told them two weeks earlier. No further problems.
Jerry
Old 09-29-2004, 03:42 PM
drmiles-
I should have read all the way through your post. I looked at the title, saw air suspension, and skipped it since mine doesnt' have the air suspension.
Anyways, the bigger issue. I get in the truck today and Lo and Behold, no warning... WTF??? I guess my H2 was spying on me last nite and saw me type this thread and got concerned that I might just trade her in for the H1 Wagon if I were to take her to the dealership. I'll wait to see if it pops up again...
-HUMMERDOGG
Old 09-29-2004, 05:56 PM
drmiles's Avatar
There have been reports of the BCM malfunctioning Intermittently before failing completely.
They returned my truck the first time saying that it fixed itself, and to see if it happened again
Old 09-30-2004, 04:19 AM
Ed G.'s Avatar
More than likely it will come back. Mine went through a cycle of showing the warning and not showing the warning. About the 3rd or 4th time it stayed on for good.
Ed
Old 07-07-2008, 04:18 PM
BITURBOAMG BITURBOAMG is offline
BITURBOAMG is on a distinguished road
Default Re: LEFT REAR DOOR AJAR
What is the bcm and can it be changed out at home?
Old 07-07-2008, 08:53 PM
MDimitri's Avatar
MDimitri MDimitri is offline
The BCM (BODY CONTROL MODULE) otherwise known as Chassis Brain Box, is located behind the headlight switch. It has 6 plugs in it. There really should be no reason to remove the BCM as it can be re programmed in the truck with a class 2 scanner that is capable of doing function tests. But the location of the BCM is top left of instrument panel above the fuse block. It is item number 1 in the picture.
(1)Body Control Module (BCM) - C1(2)BCM - C2(3)BCM - C4(4)BCM- C3(5)BCM - C5(6)BCM(7)Data Link Connector (DLC)(8)Fuse Block - I/P - C1(9)Fuse Block - I/P(10)Splice Pack SP205
Looks similar to the below image: With the exception that there are two more BCM connections (White rectangular multi prong box), rather than the one depicted below.
HUMMER » H2 » Wiring Colors & Specs
12 VOLTS red + ignition harness
STARTER 1 yellow + ignition harness
IGNITION 1 pink + ignition harness
IGNITION 2 white + ignition harness
ACCESSORY 1 orange + ignition harness
ACCESSORY 2 brown + ignition harness
KEYSENSE lt. green - lt. blue plug, pin a1 at bcm
Notes: The BCM (Body Control Module) is located behind the headlight switch. (See above diagram).
POWER LOCK lt. blue - purple plug, pin b3 at bcm
Can also use Directed interface module 456G.
POWER UNLOCK white - purple plug, pin b2 at bcm
DISARM NO UNLOCK see factory alarm disarm
FACTORY ALARM ARM arms on lock
FACTORY ALARM DISARM lt. green - driver door module in door
DOORLOCK MOTOR gray
DOOR UNLOCK MOTOR tan
PARKLIGHTS POSITIVE brown + driver kick panel
PARKLIGHTS NEGATIVE gray/black - brown plug, pin b2 at bcm
HAZARD white - steering column
TURN LEFT dk. green + steering column
TURN RIGHT lt. green + steering column
REVERSE lt. green + black plug, pin f at bcm
BRAKE white + brake pedal switch
PARKBRAKE lt. blue - lt. blue plug, pin a7 at bcm
TRUNK PIN pink/black - purple plug, pin a1 at bcm
DOMELIGHT SUPERVISION comes on with disarm
TACH white ac pin 10, green plug at pcm
Notes: The PCM (Powertrain Control Module) is under the hood on the driver side next to the battery. The tach and vss wires are also found behind the instrument cluster. For tach can also go to any fuel injector and use the wire that is NOT pink.
MEMORY SEAT 1 red + driver door module in door
MEMORY SEAT 2 pink + driver door module in door
HORN black or black/yellow - column or gray plug at bcm
Immobilizer: Passlock 2
Hope this helps ya!
Cheers!
Old 07-07-2008, 11:20 PM
Thanks is there anything I can do with the current bcm or do I just need to replace it? This door ajar really bugs me as I have the amp steps and the right side step stays down now as it thinks the door is open. Any help is much needed thank you.
Old 07-07-2008, 11:34 PM
Any one have a cost on this bcm?
Old 07-13-2008, 01:09 PM
HummerMann's Avatar
I couldn't find any BCMs online or on Ebay. I have an H2 '06 parts CD and the price in '06 was $298. I'm guessing it runs in the 300s now and you will probably have to go to the dealer. Have you tried disconnecting the battery and reconnecting it?
Hummer, like nothing else
Old 07-15-2008, 03:05 AM
No I have not, is that meant to help?
Old 10-07-2008, 09:57 PM
Well it was ok for awhile but the right rear door is the bad sensor. It will not open the amp step or put it down. I am wondering if it is the bcm or that door's sensor. I think it is the reason my factory alarm keeps going off at random times. Out of no where the door will read ajar and the amp steps goes down then the factory alarm goes off. Is there any way to disconnect that one door so the truck wont read it open or closed?
Old 10-21-2011, 09:07 PM
Anybody know how to by-pass this so the air suspension will work?
Old 10-22-2011, 08:11 AM
Hellz Hellz is offline
i have had this same problem, and bypassed using a heavy gauge wire and jumped the pins on the BCM.
i dont have access to my H2 right now to show which pins i jumped, as i am deployed right now.
you might be able to find the layout some where online or here.
as a suggestion, jump it to the rear hatch door instead of one of your other doors.
right now i have it jumped to the drivers door, but when ever i hit the button to roll down a window, it unloaks, and locks my doors. basically breaking the connection.
so if you jump it to the rear hatch, it should solve the issue all together.
Old 10-25-2011, 11:28 PM
Any pictures?
