Old 07-10-2008, 01:48 PM
Sydonnie's Avatar
Sydonnie Sydonnie is offline
Sydonnie is on a distinguished road
Question Has Anyone Ever used....??
Nail Polish remover to get out marks off their vehicle? There are some marks on my car and no matter how hard i scrub i just spread it a bit.. so do you think if i try nail polish remover to get out the marks if it will ruin the paint?
Help...
HUMMER-EYES
Old 07-10-2008, 02:19 PM
06-H3's Avatar
06-H3 06-H3 is offline
06-H3 is on a distinguished road
Default Re: Has Anyone Ever used....??
What kind of marks? Bug marks? Bird poop? Road tar? I've never tried nail polish but a light coating of WD40 followed by some elbow grease can remove a lot of gunk without damaging the paint.
Old 07-10-2008, 03:59 PM
6pack 6pack is offline
6pack is an unknown quantity at this point
I'd be worried it would damage something. They make some heavy duty stuff to remove road tar and bugs. Have you tried that?
2007 H3 Lux/Adv 5 speed, Gibson Extreme Duals cat-back, K&N FIPK, PCMforless tune, SAW torsion bars, Samco Shackles, Fox Racing shocks, Trail Duty Bump Stops, 35" ProComp Xterrain tires w/Tactical Rims, Gobi Stealth Rack
Old 07-10-2008, 05:09 PM
Big Dad's Avatar
Big Dad Big Dad is offline
I've used a kerosene soaked rag to remove bugs, tar and some of the black marks from the automatic car wash's rubber contact wheels....
But the state of California has determined that kerosene coming in contact repeatedly with a rat's eye will cause it to lose its eyesight and possible mutate into some form of cancer...so be careful.
Old 07-10-2008, 05:39 PM
lamric's Avatar
lamric lamric is offline
lamric is off the scale
Goop Remover works pretty well, as does rubbing alcohol.
"Crisis is the rallying cry of the tyrant".
-James Madison-
Old 07-10-2008, 06:48 PM
fourfourto's Avatar
with all the responses,but nail polish remover will eat right through the paint or at the very least melt into the paint. A clear coat rubbing compound will work if you take your time and use a circular motion .
Old 07-10-2008, 10:02 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
i had some scratches i bought Maguires or somethig like that and it came right out
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 07-10-2008, 10:26 PM
Sydonnie's Avatar
could be road tar.. they are reaaal tiny spots.. you have to have hummer eyes to see it... I do.. when i scrape it with my finger nail some comes off. what is WD40 and elbow grease?
HUMMER-EYES
Old 07-10-2008, 10:27 PM
Sydonnie's Avatar
nope, i am about to though.. thank you.. any suggestions??
HUMMER-EYES
Old 07-10-2008, 10:28 PM
Sydonnie's Avatar
well thank you.
HUMMER-EYES
Old 07-10-2008, 11:35 PM
Major Tom's Avatar
Major Tom Major Tom is offline
Major Tom is on a distinguished road
Wink Re: Has Anyone Ever used....??
go to any auto body supply shop and buy a can of wax and grease remover works great
Old 07-11-2008, 01:31 AM
HummerJim's Avatar
I would NEVER use nail polish remover on the finish of a car! What type of marks are you talking about. Are they swirl marks or something that you could use rubbing compound on, however, a little rubbing compound goes a long way. If it's swirl marks, I like Maguires swirl remover, often used on classic cars and available online or in many automotive departments. For tar I use WD40 on a watered down rag, and for bugs nothing beats Coca Cola.
Old 07-11-2008, 02:01 AM
Sydonnie's Avatar
wow! thank you... i think it is road tar marks... tiny black spots... i will search for the WD40.. hmmmm... thanks y'all!
HUMMER-EYES
Old 07-11-2008, 01:57 PM
fourfourto's Avatar
No need to search WD40 its a spray lub that should be at all auto stores and you can also find it at the grocery store.
You might as well spray your lock cylinders,door hinges,hood latch,parking brake ect,go to town with it
Old 07-11-2008, 02:34 PM
06-H3's Avatar
Seriously? Well I see the WD40 was pointed out, but you've never been told to put a little elbow grease into something?
Elbow grease is the extra effort that you might need to put into something to get the job done. You can't buy it (ok, maybe you can hire it out) you're just born with it.
Old 07-11-2008, 09:31 PM
lamric's Avatar
Latches and hinges on the doors and hood should be lubed with white lithium grease.
-James Madison-
Old 07-12-2008, 12:28 AM
Sydonnie's Avatar
No, i have never been told to grease anything because everything i have is well lubricated. thanks for explaining though.
HUMMER-EYES
Old 07-12-2008, 12:29 AM
Sydonnie's Avatar
thank you,,, the pic helped..
HUMMER-EYES
Old 07-12-2008, 01:36 PM
fourfourto's Avatar
Dont trust the dealer to lube everything up,I had my first 2 oil changes done at the dealer and they said they were going to lube all pivit points latches ect the either forgot or didnt bother.
I do it every oil change.
I also use white lithuim spray grease over the Wd40 on everything exept key holes.
Buy a can of each its good to have around and they last a long time.
Old 07-14-2008, 06:05 AM
Thumbs up Re: Has Anyone Ever used....??
Try Brake Cleaner or Electronic tuner and contact cleaner.
H2 REBEL lennyrebel
