Old 07-24-2008, 12:16 AM
TedW TedW is offline
TedW is on a distinguished road
Default 08 H2 AirCon Problems
Hi guys,
Bona fides first, 130k on an 03 H2. Traded it in on an 08 about 8 mos ago. 14K on the new one only 8mos old. I'm in CT, so one can expect warm, humid summers. Original compressor failed and was replaced 2 weeks ago. After replacement, all went well for 3-4 days til we hit 85-90 dgf temps w/70%rh.
At that point the a/c could not keep up. Using 2 different temp measuring devices, IR and contact, I tested the air output of my H2 against my wifes 05 3/4 ton Suburban side by side. My a/c was pushing air out at 18mph at 70dg! My wifes truck with 43k miles was pushing air with SAME settings at 25mph 42dgs!
Local dealer, my opinion the best in CT, is now telling me my system is w/in spec. Yet, they are replacing the compressor again! Techie doing the service called me and said (sorry for the direct quote) "the 08 a/c's "suck"". Spoke later to the service manager who said "???, we haven't seen many problems)".
He did not know the tech had called.
I can only see this escalaling into a "P...ing contest". All I know is that paying as much as I did for this truck, I expect it to have a/c. Right now, for work I cannot take a client in the truck with me. W/an outside temp of 90, it is down right warm in the truck. I also regularly haul 5000lbs trailer, can't wait to do that when its warm!
Anyone got any thoughts or comments? 'cause I'm going to have to push this to a new level if the 2nd replacement compressor doesn't solve the issue.
Have a Hummer of a day!
Ted
Old 07-24-2008, 01:47 AM
Little General Little General is offline
Little General is an unknown quantity at this point
Default Re: 08 H2 AirCon Problems
We have had some 100 degree days and mine hasn't missed a beat. Hope you get it fixed, maybe with such dealer inventory a buy back is in order.Check the lemon law. I have had a Ford Super Duty 6.0 bought back and an Audi A6. The Audi, every time you turned on the radio the back window went down. Afer a week at the dealer, they said go pick out another.......
Old 07-24-2008, 03:03 PM
Thanks! We'll see what happens....BEst!
Old 07-26-2008, 02:14 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Heres the ac performance table for ya.
Ambient Air Temperature
Relative Humidity
Service Port Pressure
Maximum Left Center Discharge Air Temperature
Low Side
High Side
13-16?C (55-65?F)
0-100%
200-283 kPa (29-41 psi)
945-1234 kPa (137-179 psi)
11?C (52?F)
19-24?C (66-75?F)
Below 40%
228-310 kPa (33-45 psi)
1082-1413 kPa (157-205 psi)
14?C (57?F)
Above 40%
248-338 kPa (36-49 psi)
1131-1469 kPa (164-213 psi)
15?C (59?F)
25-29?C (76-85?F)
Below 35%
276-379 kPa (40-55 psi)
1303-1696 kPa (189-246 psi)
18?C (64?F)
35-60%
1310-1709 kPa (190-248 psi)
18?C (64?F)
Above 60%
290-400 kPa (42-58 psi)
1358-1765 kPa (197-256 psi)
19?C (66?F)
30-35?C (86-95?F)
Below 30%
317-434 kPa (46-63 psi)
1544-2006 kPa (224-291 psi)
22?C (72?F)
30-50%
324-441 kPa (47-64 psi)
1558-2034 kPa (226-295 psi)
22?C (72?F)
Above 50%
365-510 kPa (53-74 psi)
1675-2179 kPa (243-316 psi)
26?C (79?F)
36-41?C (96-105?F)
Below 20%
400-552 kPa (58-80 psi)
1917-2503 kPa (278-363 psi)
28?C (82?F)
20-40%
393-546 kPa (57-79 psi)
1910-2496 kPa (274-357 psi)
28?C (82?F)
Above 40%
1910-2496 kPa (277-362 psi)
28?C (82?F)
42-46?C (106-115?F)
Below 20%
448-621 kPa (65-90 psi)
2172-2834 kPa (315-411 psi)
31?C (88?F)
Above 20%
462-634 kPa (67-92 psi)
2220-2896 kPa (322-420 psi)
32?C (90?F)
47-49?C (116-120?F)
Below 30%
531-731 kPa (77-106 psi)
2379-3116 kPa (347-452 psi)
43?C (109?F)
Old 07-26-2008, 01:36 PM
mikejr's Avatar
mikejr mikejr is offline
The a/c in the 08 works a heck of alot better than the 06 we had. If you crank up the a/c in the back...you can hang meat in the truck it gets that cold.
We've had the truck down in SC with mid 90 ambient temps and high humidity and it never missed a beat.
2009 H2 Silver Ice LE
Old 07-29-2008, 02:19 PM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
When you have a compressor failure all kinds of crap can circulate into the system. A new compressor won't work properly if the rest of the system has blockage or restriction.
On older vehicles the orifice tube would be blocked, I haven't worked on an H2 A/C to know if the system is similar, but suffice to say if the system wasn't properly cleaned when the new compressor was installed, it will never work properly.
I would talk to the Service Manager and see exactly what work was done, chances are a lazy tech bolted on a new compressor, pulled a vacuum and charged it, and the rest of the system is contaminated with the remains of the old compressor.
Don't accept a poorly performing system and don't allow that flunky to do the work again, 08's have no A/C performance problems, if they did you'd hear about on this forum like a rash.
