08-05-2008, 02:46 PM
Tire
I have 49000 on the stock tires and the sidewall blew a leak. Glad it was sitting in the driveway when it went down. Need to get a good floor jack.
I have the standard P275/ and I want some more rubber on the road. I spend most of my time on the highway. If I go to P265/ I will get wider and a little taller. My question is - will it throw off my speedometer by much?
2006 Slate Blue Metallic H3, FlowMaster exhaust, True Flow cold air intake system, Ground Force rear lowering kit, custom locking fuel door, chrome hood grill w/handle, US Speedo gauge kit (chrome and red numbers), Custom rear tire cover, chrome tail light guard, custom paint on skid plate, new pin stripping, USMC front license plate.  Semper Fi
08-05-2008, 04:56 PM
Re: Tire
08-05-2008, 11:47 PM
Re: Tire
not at all. It will be so minor!!! You could even fo to a 285 and still have your dealer change the calibration without issue and effecting mpg. Now if you went to a 315, you will be off about 6 mph at 55 and your mpg will decrease about 3mpg. hope that helps.
08-07-2008, 12:11 AM
Re: Tire
Thanks for the help. I did go up to P285 and they are alot better than the stock ones. My dealer even threw in a set of chrome wheels for an couple hundred extra. Not a bad deal, however I noticed the front pads were getting thin so I had to get a brake job. Better sooner than later.
Thanks again for all the info.
