Old 08-07-2008, 05:21 AM
Dmax Dmax is offline
Dmax is on a distinguished road
Default H2 problems??
I have an 03 H2 and am having a problem with I think electrical or something else that I hope you have some insight with. I try using the remote to unlock it and notice the lights are dim and when I get in turn the key I get nothing. Very dim lights on the dash and the key can't be turned to pull out. I have replaced the battery twice and have had other things happen but the same outcome no power. I have had where I was sitting just putting the [assenger window down and when it got all the way down sounded like clicking like it was still trying on the track to go down. and when I put it up the same noise if I help the switch. When I got out and pushed the lock button dim lights and won't start (not enough juice)
The last couple times when I turn the key and it won't start the radio cd player seems to keep spinning like searching for a cd to play even with it off. I don't have enough power to get the key out of the iginition.
The seats in the front won't work sometimes power or heat. they work in the rear. I don't know if something is shorting out or what is draining the battery. It happens when I am home and when I go to leave after it sits a couple days. The remote is programmed to the seats. Please any help is appreciated.
Old 08-07-2008, 06:50 AM
Default Re: H2 problems??
1. Bad battery or connectors not correctly tightened
2. Alternator not charging battery properly
3. Electrical drain somewhere - what kind of after-market stuff is in the rig?
Old 08-07-2008, 02:25 PM
HummerHippy's Avatar
This wont make any sense after DRTYFN changes his avatar but...
"Warriors. Come out and play"
29-Jul-2008
Old 08-07-2008, 04:39 PM
Battery connectors are good, Just have remote start which was the first thing I had disconnected and still have the problem. Just disconnected the seats to see if it happens again. Thanks for the tips. Greatly appreciated.
