07-28-2008, 01:05 AM
Questions for 442...
Hey 442,
I was reading your sig and had some questions about your setup if you wouldnt mind answering them...
A) Where's the fridge?
B) The Eclipse system, did you keep the stock speakers or did you upgrade those as well?
B1) If you were stock at the start were you base or monsoon?
B2) If monsoon, did you need to bypass the monsoon amps?
B3) If Base, did you need to add an amp or was the Eclipse's built in amp enough to satisfy?
C) As to the nav system; is that dvd based? Flash drive based; how is it updated?
D) What is the circular handle device on top of your battery next to the light and what type of light is that anyways?
E) Did changing the stock radio to the Eclipse require any changes to the Onstar system or did that continue to work normally?
F) Did you need any special adapters for Sirius Sat. to work, also does it work through the eclipse touchscreen or do you still need the Sirius head unit (e.g. sportster 5)?
G) Are there video outs to run lines to head rest monitors?
H) Now that you have the Eclipse system, any regrets, would you have rather gotten something else?
Perhaps a list of Pro's/Cons?
Thanks,
Rich
07-28-2008, 08:05 PM
Re: Questions for 442...
Hey 442,
A) Where's the fridge? In the cargo area(see pic)
B) The Eclipse system, did you keep the stock speakers or did you upgrade those as well?stock speakers
B1) If you were stock at the start were you base or monsoon?Base
B3) If Base, did you need to add an amp or was the Eclipse's built in amp enough to satisfy?No amp It sounds good but a sub woofer wouldnt hurt.
Dvd 2005 ed Ill buy a new one in 2010
D) What is the circular handle device on top of your battery next to the light and what type of light is that anyways?It a GM underhood light Used on late 80's early 90's chevy trucks.Theres a guy on ebay that sells new ones,it has a sution and magnetic mount 20/25 feet of wire and cranks back in by the handle.
E) Did changing the stock radio to the Eclipse require any changes to the Onstar system or did that continue to work normally?Yes I had it put in by a recomended installer.
F) Did you need any special adapters for Sirius Sat. to work, also does it work through the eclipse touchscreen or do you still need the Sirius head unit (e.g. sportster 5)?Yes but i didnt get it hooked up the head unit is set up for it though.
G) Are there video outs to run lines to head rest monitors?I think I seen the wires bundled up when I was poking around.
H) Now that you have the Eclipse system, any regrets, would you have rather gotten something else?No
Perhaps a list of Pro's No problems in 3 years
They hooked up a switch to enable the DVD to plat when moving also enabled Nav functions when driving.
Added a rear cam.
/Cons?None so far
08-02-2008, 03:03 AM
Hey 442,
Thanks for all that detail.
Regarding E) Did changing the stock radio to the Eclipse require any changes to the Onstar system or did that continue to work normally? Yes I had it put in by a recomended installer.
If you don't mind me asking, what did the whole purchase/install cost out the door? And Onstar no longer worked or continued to work normally?
08-11-2008, 02:34 AM
They installed a Onstar module and it works fine .
The total install was $2,000 no tax including rear cam and auto start was a extra $200.
Link: http://www.elcovaforums.com/forums/s...hlight=eclipse
