Old 09-07-2008, 10:14 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
Default Service Air Suspension
I read ealier in a thread, that if this comes up on your dash display, that it is more than likely a ride height sensor. So, if this comes on, and the compressor for the airride is not turning on, and the height control is not turning on, is that still just a sensor, or do I have bigger problems? Rear end is sitting lower as a result too...
Old 09-07-2008, 10:30 PM
working Hummer's Avatar
Default Re: Service Air Suspension
All I can tell you was when my light came on it was the sensor. Replaced and all was OK
Old 09-07-2008, 10:46 PM
H2Much's Avatar
Thanks. So, when your sensor was out, did it completely turn off the compressor until the sensor was replaced?
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 09-08-2008, 02:05 AM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
I had mine replaced recently too. On mine, the compressor would still come on. Sometimes it would raise, sometimes it wouldn't. I also got the service air suspension when the cap wasn't on the plug in the back. But in each case, the compressor would still run. Might be something else electricial to initiate the compressor instead. Not sure if it's simple (like a fuse) or more complicated (replace compressor)....
Old 09-08-2008, 04:52 AM
H2Much's Avatar
Thanks, I will have it in the shop tomorrow, hope the compressor isn't blown.
