Old 09-09-2008, 10:21 PM
HummerHippy's Avatar
Default Exhaust Manifold - Expensive
Just had mine replaced under warranty to fix a rattle. Dealer told me the part was around $500 and labor was probably close to $300! Wow!
29-Jul-2008
Old 09-10-2008, 04:27 PM
6pack 6pack is offline
6pack is an unknown quantity at this point
Default Re: Exhaust Manifold - Expensive
What was the rattle like? I have two currently, one rattle is my exhaust clamp, but the other one seems to be coming from the engine, in front of the center of the dash (as I sit driving). And happens as I'm letting the clutch out in first to get moving. I haven't got in there to look around yet, but I was thinking there was a heat shield around that manifold that was loose.
2007 H3 Lux/Adv 5 speed, Gibson Extreme Duals cat-back, K&N FIPK, PCMforless tune, SAW torsion bars, Samco Shackles, Fox Racing shocks, Trail Duty Bump Stops, 35" ProComp Xterrain tires w/Tactical Rims, Gobi Stealth Rack
Old 09-10-2008, 06:07 PM
It sounded like a heat shield type rattle. From under the engine, couldn't tell if it was left or right side. Dealer said that they've seen a few, where the pipe moves and cracks a bit by some bolts (I dont know where he referred to) and finally you get a rattle.
Rattle was present when engine was under stress or under a load. Not when cruising/coasting. Hope that helps.
29-Jul-2008
Old 09-11-2008, 05:00 PM
It does. Thanks.
