Old 10-11-2008, 11:01 AM
Rred's Avatar
Rred Rred is offline
Rred is on a distinguished road
Default question about the H3 adv.
I'm looking at used H3's on the market. And I was wondering on how to identify an adventure model? I'm wanting one. Anyone know?
06' H3 white/black adv/lux
Blistiens at all four corners, leveled, 35" Toyo M/Ts
Old 10-11-2008, 11:02 AM
Rred's Avatar
Default Re: question about the H3 adv.
oh, and does the adv come with the 5spd?
Old 10-11-2008, 01:56 PM
Vandakeg Vandakeg is offline
Vandakeg is off the scale
If you can't tell by the tires, you can check inside for the rear locker button.
Old 10-12-2008, 05:31 PM
H3slate's Avatar
H3slate H3slate is offline
The 5 speed comes standard on all H3 models, but 95% of H3's have the automatic transmission.
Old 10-13-2008, 03:25 AM
HummerHippy's Avatar
yep, rear locker button, and 33" tires instead of 32" are the only easily visible signs I think.
29-Jul-2008
Old 10-14-2008, 06:48 AM
Rred's Avatar
Where is the rear locker button located?
Old 10-14-2008, 12:55 PM
on the dash ...
Old 10-14-2008, 04:05 PM
on the dash ...
Last button on right, above radio, along with the 3 4wd buttons.
29-Jul-2008
Old 10-14-2008, 10:19 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
defintly easiest way is the tires the 33" bridgestone dueler all terrains are the easiest clue to tell them apart, however, the only sure way to tell is by looking for that rear locker button.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 10-16-2008, 06:21 AM
blindzebra's Avatar
the pumpkin on the adv has a impression on the right side. The std model is round all around
Old 10-16-2008, 11:28 PM
3Hummer's Avatar
blindzebra...what do you mean the pumpkin?
2017 VW Jetta S
/''T''|[___|___]
Old 10-17-2008, 12:33 AM
blindzebra's Avatar
your rear dif cover. look underneath the rear bumper, what you see is the dif cover
Old 10-29-2008, 06:43 AM
Rred's Avatar
Does the locker button look more like a traction control button found in most other vehicles? It has a rear view of the vehicle with to tire tracks under it?
