11-11-2008, 03:20 AM
questions about leveling
wheni leveled my truck it came out to about 23.75". one thing i noticed was that the tires pull inwards when you level it out? but not both. the driverside tire is in a little bit and the side wall is flush with the fender but in the pass side its about a 3/4 of an inch out. im running 285/75 Mtz tires and they always were wider then the fender but now when i leveled it out, the driver side is in. is that a problem?
11-11-2008, 03:35 AM
Re: questions about leveling
I'm pretty sure that you're supposed to get alignment done after leveling
11-11-2008, 03:37 AM
Did a search on leveling and found this that looked close to what you are looking for...
http://www.elcovaforums.com/forums/s...light=leveling
The search pull down is your friend!
11-11-2008, 10:58 AM
or just have W do the search for you...he's good at it !!!
11-11-2008, 10:11 PM
ok, got everything done. alignment came out good. what a differance with bilstiens. ive got the cognitos in the front and i added a pair out back as well. like night and day. and it looks much better as well. i hated that stink bug stance!
