11-17-2008, 01:18 AM
mirror display dead
Hello all. I just had my windshield replaced - out of warranty.
Anyway, get in the truck and the inside rear view mirror heading/temp display is dead. I called the guy that replaced the windshield and he said they just unscrew with a torx - he didn't unplug it or start the truck or anything. Seems a it must be some occurrence of the windshield swap.
Can anyone give me some clues as to what to check or where to start? What the wiring should be or what I can check with a voltmeter? Is there some kind of reset trick? Also - which fuse protects it? I can't figure which one it is from the diagram - I did pop out the 'info' (don't remember the number of the fuse - it's in the lower right of the box) fuse and it is fine.
I figure I can pick up a working mirror cheap enough and replace it, but, I am thinking something is dorked and I should (with the help of you guys on the forum) be able to fix it. Also, I can't imagine the mirror display died so coincidentally and I am afraid if I buy a new mirror, it may be just fine, but, not work as the prob might lay in the wiring, the connector, a fuse, somewhere else.
Thanks.
11-18-2008, 12:11 AM
Re: mirror display dead
unplug it and than plug it back in ,it is most likely a bad connection.
A government big enough to
you have.
-- Thomas Jefferson
11-18-2008, 01:34 PM
Thanks IRA. Tried that (a couple of times). Even pushed (and tugged a bit, I guess) the loom to see if any connections were loose going into the connector. No luck.
I think I will try poking a pin lead into the connector to see if it is at least getting juice.
Anyone know which fuse the mirror is on?
11-18-2008, 02:34 PM
Is there a green light still showing in the bottom corner? If you press the black button it will change readings or turn of the display.
Tim
11-18-2008, 10:48 PM
Thanks Tim. Nope - no green light - no light, at all.
I suppose by the black button you mean the comp or temp buttons? Is there a black button I haven't noticed? Maybe you mean the 'button' to the left of the comp button?
I do see two square holes - one to the left of the comp/temp button and one to the right. The smaller hole on the left looks to be what was a light, maybe, and the hole to the right looks to be a light sensor..
Removed the connector from the back, again, and pushed the loom leads into it (they didn't move, just thought to push on them) - still nothing.
Felt all over the thing (and looked at it) and don't see anything else that might reset it. Is there some strange combo of holding both the comp and temp buttons while starting the truck and pressing the gas three times (like resetting the Oil Engine Life DIC)?
11-18-2008, 11:10 PM
I can't tell you how to fix it, but I can offer some good advice. If it was working before you had the windshield replaced and not after, call the people who did the work and let them resolve the problem. Quit spending your time on the problem and let them fix it. They broke it, have them fix it!
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
11-18-2008, 11:34 PM
I 100% agree, when I had my windshield replaced and if I came home and the mirror didn't work I would of turned right around and took it back to them and said "call me when the mirror works". That would be rediculous if you just let it go.
11-18-2008, 11:46 PM
You guys are right....
The guy did the whole job, including labor, for $195. I figured it was so inexpensive - and he did a 'good' job (good, if the mirror wasn't torqued) - that I was hoping for some quick reset trick from the forum. Wouldn't have to bust his chops, no harm, no foul, and I would be good to go.
Here is why you guys are totally on the mark - I removed the mirror to get a better angle on the connector to check for bent pins or something - all was ok - as I followed the loom upwards, right where they meet the windshield and go into the headliner at the back of the console, there are a couple of cut wires.
You get what you pay for, I suppose. Anyway, just got off of the phone with him - he will be having a tech come out to fix it up.
Thanks again, to all and the forum, though, I probably should have done what you guys said in the first place - just told him, it was fine, now it isn't - effin fix it (without bugging the forum).
11-20-2008, 02:25 AM
I didn't have that problem, but they failed to secure the plastic side pieces with mastic or double sided tape after they replaced my windshield and it made a very loud buzzing noise. They were good about coming back and fixing it, even though I thought it was the sunroof deflector at first. WOW! 195 is a good price, I paid 405 for mine installed!
11-26-2008, 11:31 PM
Take your mirror off and then check the connections on the back. Maybe they removed the plug and when putting it back on bent or broke one of the pins.
11-27-2008, 03:00 AM
Don't touch anything!!! Bring it back and have them fix it.
