Old 11-18-2008, 06:40 PM
Scarsman's Avatar
Scarsman Scarsman is offline
Default H3T drivetrain decicions...
Hi! This is my first post here, but I have been lurking and reading for some time. While I do not have a Hummer right now, I will be getting an H3T at some point. I have not decided if I want to get one right away, or wait and see if they come out with a different engine option next model year.
Ultimately I would like the 5.3 with the 5 speed and the super low 68.9:1 crawl ratio, but they are not offering that.
Now, I know with the automatic you have some "give" due to its nature, so do you think that would make up for the difference between the 68.9:1 ratio you get with the 5 spd I5 and the 50.6:1 ratio for the V8 auto? I have seen some video of the V8 going down some really steep hills off road, and they were actually giving it gas to speed up because it was holding back so well. So maybe it would be alright.
I would really like to have the power of the V8 for towing, but I am really after the off road ability, so I would rather go for the I5 if the lower ratio will clearly be a benefit off road.
I would like to drive one of each and see how they feel, but the dealer near me only has three I5's and one V8, and they are all autos and all "blinged out." And none of them have the offroad package with the lower gearing, either. They also don't have a Hummer demo course.
So, which set up do you guys think would be better?
Old 11-18-2008, 07:19 PM
Desert Dan's Avatar
Default Re: H3T drivetrain decicions...
I too would want the V8 with a 5-speed manual.
The Alpha HT3 with the Adventure package has front and rear lockers with the 4:1 low range as well as 33" tires.
The V8 models have a cast iron front diff housing but my question is does the I-5 with a front locker aslo have the cast iron front diff housing?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 11-18-2008, 08:50 PM
Scarsman's Avatar
So far I am under the impression that only the 5.3 with the off road package comes with the cast iron diff. I could be wrong, but that is what I have been told. But then the dealer here is not really a "real" Hummer dealer. They are more about the pavement princess market, I think.
Old 11-18-2008, 10:36 PM
Desert Dan's Avatar
Darn I'll have to get a V8....... LOL!
I hope the put the cast iron housing in all the H3s especially with the front locker
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 11-19-2008, 05:37 AM
Gholan's Avatar
Gholan Gholan is offline
Gholan is on a distinguished road
these are the specs as listed by hummer for H3T
3.7L Manual: 45.1:1 with Opt. off-road suspen. package 68.1:1
3.7L Automatic: 36.8 with Opt. off-road suspen. package 56.2:1
5.3L Automatic: 33.1:1 with Opt. off-road suspen. package 50.6:1
I can't remember for sure but, I believe since the off-road suspen. package comes with front locker the cast iron dif is a part of it.
I hope that helps
Old 11-19-2008, 05:03 PM
After having two H3's with the I5, and now one with the V8, there is no way in hell I would ever go back to the I5.
The I5 is OK, but since you mentioned towing, I say go for the I5.
Your comment on giving the auto gas to go down hill is spot on!!!
The lower gear ratio on the manual? I'm not sure its worth that little bit.
Since you are going to be off roading this truck...ane more than likely adding 35's, I say go with the V8. You'll get the cast iron front diff, more power, torque for towing and moving larger tires around.
Go drive both and see what you think.
Old 11-19-2008, 05:37 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
the v-8 only comes with the automatic you cant get it with the manual 5 speed.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 11-19-2008, 06:20 PM
Scarsman's Avatar
Yes, I know the V8 only comes with the auto. I talked to a salesman yesterday, and he said there is no way they would make one with a manuel. Right now all they have are I5 autos. I guess I could drive one of them, and then drive an H3 manuel to see how they feel. I imagine the H3 should feel about the same as the H3T.
By the way, they just put one of those slant back canopies on one yesterday. Boy does that look good!
Oh, and I confirmed the only way to get the cast iron diff is with the V8. It is looking like the V8 will be the way I will have to go. It will just bug having to spend all that extra money for a bunch of extra stuff I don't really want. I'll have to check into how much they can strip down the Alpha.
