12-06-2008, 07:26 PM
Burned CDs in a h2?
is there anyway to make them play in the h2. most of the time they skip, but does anyone know how to get them to work right?
12-06-2008, 10:20 PM
Re: Burned CDs in a h2?
I have an ENtronics DVD±RW Dual Layer burner and most of my burned CDs play fine in my H2. Just make sure your burner is capable of writing and re-writing DVD-RW DL and DVD+RW DL.
Hummer, like nothing else
12-06-2008, 10:59 PM
Never had any problems
12-06-2008, 11:44 PM
x2
12-06-2008, 11:56 PM
what type of disc are you using? and what size?
12-07-2008, 02:39 AM
Originally Posted by Hummer Guy
x2
x 3
I have used the cheapest from Disc Makers that were free with the purchase of a burner and I have used Memorex 700MB without issue. Mostly burning from iTunes in a Plextor PX-740A.
It may be your burner. The burner in my wife's laptop has issues and those discs skip in both our cars.
E
2006 Hummer H2 Adventure - Yep it's a hybrid! - SOLD
2006 Infiniti G35 Coupe - SOLD
2005 Honda Aquatrax R-12x - SOLD
2012 Dodge Challenger SRT8
2012 BMW X5 xDrive50i
12-07-2008, 04:15 AM
E
concur
12-07-2008, 10:03 AM
Some time ago, burnt cd's started skipping. My friend put a cleaning disc in the cd player and since then I had no more problems
12-07-2008, 02:24 PM
X4
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
12-07-2008, 02:57 PM
X5
I've used the burner on my Gateway Computer and all the discs played without problem in the Hummer.
12-07-2008, 04:59 PM
I'm gonna get a cleaning disc, but does anyone know if Cd-RW disc play better than Cd-R?
12-07-2008, 06:08 PM
I've used both with no problems. My biggest problem is being careful storing them. I normally just throw them in the console and they get scratched.
12-07-2008, 06:24 PM
Cd-RW discs are rewritable/erasable and in my experience they do not perform as well as Cd-R, especially after many erase/rewrite cycles. They are also more expensive and it doesn't make sense to use them for music.
If your disks are skipping during playback, try burning them at a slower speed. Burning at 48X and higher will produce more errors, especially with poor quality media.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
12-07-2008, 06:27 PM
thanks for all the help, ill get a cleaning disc and burn at a lower speed.
12-07-2008, 08:42 PM
I ended up burning mine at a slower speed and they work fine now. My 05' stock system never played a burned disk for 2 years until I asked this same question in off topic. Thanks to COHummer, I got it working in no time.
12-09-2008, 12:39 AM
are you using a cd-r disc or cd-rw, and what brand and size is it. also does anyone know if using a cleaning disc is safe?
12-09-2008, 05:03 AM
I only seem to have problems when using CD-RW, they skip and sometimes just stop playing altogether.
Never had a problem with a CD-R. They burn faster too.
12-09-2008, 09:34 PM
I think I'm using the CD-R Sony. See, I'm not much of a techno geek. I was having trouble getting a disk to play in my daughters Strawberry Shortcake CD player. When I tried it in the H2 it didn't work either. I had to burn the disk at 4x speed. When I found out that worked, I didn't try burning it at any faster speeds because it sounds fine to us.
When they weren't playing correctly, they sounded like they were scratched.
12-09-2008, 10:16 PM
As said buring at slower speeds can make the disc work. I had this trouble a while ago and after burning at the slower speeds I never had a problem again.
12-10-2008, 07:39 AM
I think using the cleaning disk from time to time (every couple of months) and writing them at low speed is the best deal
