Old 12-22-2008, 06:41 PM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Rear Air Suspension Problems
0 items in cart
check out your
wish list order
status your
account
SEARCH
Advanced Search FAQ View Cart Register Request a Return Customer Service GM Warranty E-Mail Us Tell a Friend Home
Search Results of Available Items
*Prices are Per Unit
Page 1: 1-1 of 1 items
GM PART # 15938306
CATEGORY: Rear Spring
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $163.16
OUR PRICE: $96.72
DESCRIPTION: SPRING
A government big enough to
you have.
-- Thomas Jefferson
Old 12-22-2008, 08:33 PM
richl's Avatar
richl richl is offline
richl is on a distinguished road
18B................
Old 01-14-2009, 04:18 PM
fbodyguy99@hotmail.com fbodyguy99@hotmail.com is offline
fbodyguy99@hotmail.com is on a distinguished road
Ok this is the deal i have a 2003 hummer h2 i used to like it now its getting on my nerves with the damn sensors i have a tech 2 i bought so it pulled these codes up in the history first one is
1 C0631 RIGHT REAR POSITION SENSOR
2ND IS C0712 LEVEL CONTROL COMPRESSOR RELAY CIRCUIT I LOVE A PART NUMBER FOR THAT SO I CAN BUY IT 3RD THE MOST FAMOUS ANNOYING ONE IS CO711 LEVEL CONTROL AIR PRESSURE SENSOR STAYS ON ALL THE TIME AND LIGHT FOR HEIGHT CONTROL FLASHES NON STOP
AND MY RIGHT IS 3.65 SENSOR VOLTS
LEFT IS 2.53 SENSOR VOLTS THE LEFT ONE GOES UP N DOWN LIKE CRAZY WITH THE SCANNER WHILE DRIVING SO WHAT SHOULD I DO FIRST PLEASE Do you guys think i need air bags too or just fix the sensors
Old 01-14-2009, 08:02 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I would start by replacing the relay. It is located below the brake master cylinder on the 03 model year just above the frame rail(dont know the part #). Then try to clear all codes. On level ground with the engine running check your level sensor data again, they should read between 2.5 and 3.5 volts, any lower or higher and they are not in the proper range when sitting still and level. If the right one still is reading high you can try to adjust it but will likely need to be replaced. If you do replace it you will then require a trim height learn procedure.
Old 03-23-2009, 08:25 PM
agood1 agood1 is offline
agood1 is on a distinguished road
How often should the compressor kick on? Mine comes on every 5-10 minutes.....I can't really tell if it is because of a leak, or that it is just doing it's job.
Old 06-30-2009, 12:19 AM
lmajor lmajor is offline
lmajor is off the scale
Mine only releases air sometimes. It happens when I park and turn off, I can hear air coming out. When I come back it will be sagging. Only once while driving did the service air come on and it sounded like the compressor was continualy running. It stopped after several minutes of driving. I checked the bags and I don't hear or see any leaks. It doesn't make sense that the bags would be leaking because once they start to leak they are not going to seal themselves back up and not leak other times. Any ideas?
Old 06-30-2009, 06:17 AM
I'm going through the same thing right now. Sometimes they leak and some times they don't. If I pump them up before turning it off it'll stay inflated indefinitely.
Old 06-30-2009, 05:00 PM
This makes me think that it is not a leaking bag but something like a valve or sensor etc. My compressor was replaced to the newer style back in 04 and seems to be working fine. Any thoughts?
Old 06-30-2009, 05:57 PM
Why don;t you guys just take out the stock bags, add factory or better yet aftermarket 2" taller coil springs. Than add a set of adjustable firestone bags. you can get teh in cab controller and you can raise lower for increased weight or added height when wheeling. Those bags are more reliable than teh stock bags and inlfate/deflate way quicker. ...just a thought.
Old 06-30-2009, 08:19 PM
IRA51's Avatar
100% CORRECT AND A GOOD WAY TO GO .
you have.
-- Thomas Jefferson
Old 06-30-2009, 09:12 PM
Thanks for the suggesstion but I'd rather keep it stock. I am at 81k now and have not had any issues so I would rather just figure out the problem. Any ideas?
Old 06-30-2009, 09:38 PM
Go to your dealer and have them figure out. GM had progarm updates to the earlier models. I was one of the first 03's to have my air bags go....and if you're in the middle of bumfu*#, you are SOL. I had to cram a 2x4 in both sides and had a nice 4 hour ride back to Denver since it was a Sunday and could not get a flatbed anywhere.
My reccomendation, pay the dealer thier service fee and see if any updates are available. you have some high miles on that H2 and things are going to start to go. This "I'm at 81K without issues" may be the start of replacing that whole system one by one. Teh aftermarket way is much cheaper/easier to go than replacing stock....unless the budgett isn;t a factor. ...my 2 cents for what it's worth.
Old 06-30-2009, 09:55 PM
I do plan to have it checked out but the reason for posting was to get an idea of what might be wrong with it before I did. Usually these things don't just happen to one car. It might just be a simple and relativly innexpensive fix that can buy me another 20k and I can take care of it for just cost of parts. I'd rather not replace the entire system w aftermarket without knowing if I can fix it easily. I saw another poster on this forum jump the gun and tear the entire system out and put springs just to find out that he could hasve probably replaced one part and fixed it. Thanks again. It might be an option down the road.
Old 07-01-2009, 06:46 PM
IRA51's Avatar
Who did the lift ?
you have.
-- Thomas Jefferson
Old 02-05-2011, 10:47 PM
H2mudder's Avatar
H2mudder H2mudder is offline
H2mudder is on a distinguished road
How hard is the removal and install of the air shock?
Anyone have a link or anything showing the process?
Old 02-05-2011, 11:56 PM
Easy Ed Easy Ed is offline
This help ?
http://www.youtube.com/watch?v=JSmkJc0RitM
Old 02-06-2011, 08:14 AM
H2mudder's Avatar
Talking Re: Rear Air Suspension Problems
Originally Posted by Easy Ed
Yeah ED, thanks a ton.
It looks pretty easy.
Cheaper than going to the dealer.
You rock!
Old 02-06-2011, 02:06 PM
Thanks but got to give credit where credit is due, IRA51 had that link in a post of his
http://www.elcovaforums.com/forums/s...ad.php?t=37006
Good luck,
Ed
You rock!
Old 05-08-2011, 11:06 PM
blkhummer_guy blkhummer_guy is offline
blkhummer_guy is on a distinguished road
i have a 03 h2 n was wondering it changing air suspension kit to a conversion coil kit would be a good idea? cuzz i was told that'll cost less prob in the future...either way i have to get something done wit it...losing air from time time n havnt had the chance to take it in the a checkup...
