Old 01-07-2009, 09:52 PM
twenty2's Avatar
twenty2 twenty2 is offline
Default Here we go again!!
About a month ago, I had a issue with a Bank 1 and Bank 2 code showing my gas was lean. Do you guys think I have a gasket leak coming from my intake manifold? Or, something else? The O2 sensors were going to be changed, but they say its kinda hard to beleive that both banks would go out at the same time?
Any help please.............
Old 01-08-2009, 01:12 AM
LEcustoms's Avatar
LEcustoms LEcustoms is offline
LEcustoms is off the scale
Default Re: Here we go again!!
I Had the same thing happen about a month ago. I was told it was my MAF, so i cleaned it out(after market MAF) same thing happened again. I was thinking possibly the cats.I will hopefully be dropping off my truck again next week to have them look at it again. Its still under warranty. If i get the issue resolved I will let you know what the problem was with mine. Till then good luck.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
Old 01-08-2009, 01:21 AM
do one of two things:
1)with engine running, pour bucket of water or run water hose over intake, esp at cyl heads to see if idle stumbles
2)spray carb cleaner or starting fluid around same area and see if idle raises.
either of these will point to leaking intake gaskets
Old 01-08-2009, 01:42 AM
Easy Ed Easy Ed is offline
This may not apply to the H2 but.....I have a 95 Neon that I pretty much re-built mechanically as a project and to also help with the $4.00 plus a gallon gas prices we had for a while
The last bit of problem I had to clear up was a code saying it was running lean. And one of the possible causes (but was not mine) for the neon to throw that code was a known problem of a cracked exhaust manifold and I do know that our H2's got a nasty habit of having the heads of the exhaust manifold bolts to break off. Maybe you have "many" of them broke and now have an exhaust leak causing the computer to throw the lean condition code.
This is just a thought and may not even be your cause but may be worth a look.
This is also the list suggested to look at in fixing the problem on the Neon
low fuel pressure
injectors
coolant temperature sensor
MAP sensor
O2 sensors
exhaust manifold
engine parts tolerance
The neon project pics are posted through out here http://s220.photobucket.com/albums/d...heri/?start=40 if you got some time to kill
Old 01-08-2009, 02:51 AM
twenty2's Avatar
please let me know what happens...
twenty2's Avatar
Ill give it a shot...
Old 01-08-2009, 05:23 AM
RippSpeed RippSpeed is offline
RippSpeed is on a distinguished road
I had issues with idle and cruising issues for awhile... I just replaced my freaking injectors and that solve my running lean issues... Then again I dont know if you guys have 80K in mileage on your rigs ????
Old 01-08-2009, 07:31 AM
twenty2's Avatar
I do.... hummm, too many things to either change or check...
Old 01-08-2009, 03:55 PM
HumminNBoatin''s Avatar
I am having these same issues. I have 83K miles on my truck. I am VERY interested to know what the turnout is!
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 01-13-2009, 08:03 AM
twenty2's Avatar
Well, my update is here. It was my MAF sensor that had to be replaced. I drove it the whole day today, and so far no engine light on...
Old 01-14-2009, 09:21 PM
I guess Ill go ahead and clean mine first and see if that helps.
Old 01-15-2009, 06:03 PM
I replaced my MAF this am. Cleared the codes and gas mileage has already increased. I guess the rest of the day will tell.
Old 01-15-2009, 09:43 PM
twenty2's Avatar
Son of a beotch!!! My engine light is back on, and the codes are still reading Bank 1 & bank 2 po171 and po174 lean.
The guy who replaced the MAF said on his reader, it said my MAF was bad causing the lean, but Im still having the problem!! Do you guys think this guy was taking me for a ride? Or, was he being honest and telling me he was correct on his reader saying it was the MAF sensor? And, now of course... he wants me to bring it back cause it may be the O2 sensors???
help again...
Old 01-16-2009, 03:12 AM
pdsq99f4 pdsq99f4 is offline
help again...
Not sure what code says "bad maf sensor". Don't bring it back to this guy. Whoever looks at it needs to check your fuel pressure (56-63psi is ok) and also check for intake leaks. Also sometimes the intake tube where it meets the throttle body gets folded under and it can pull in air from there.
Old 01-16-2009, 04:10 AM
LEcustoms's Avatar
Still havent had a chance to drop off my truck. hope to get it in the shop next week. The idle is getting worse almost like I have a rediculously agressive cam. My truck has 70k on it as well.
03 White H2
06 kawasaki stx-15f
02 yamaha superjet
Old 01-16-2009, 03:08 PM
twenty2's Avatar
Well, Im taking it back..... I'll keep you posted on whats up next...
Old 01-16-2009, 03:22 PM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
Actually it might be the cat.
I had the same issue, had a code that said bad MAF (don't know the code, just got the info from the dealer) changed the MAF and still had the same code.
Then into the shop and being in Denmark where the shops don't know wery much about Hummers resulted in me changing the engine (at my own cost) because nobody cared to check the cats.
Regards
Rene
Old 01-16-2009, 07:49 PM
Same thing Here. I am now getting the same Codes. I did have my intake tube folded at the throttle. So I pulled it off and boiled it to get it hot and expand. As it was ZERO degrees out last night. After boiling I ran it outside and it slid right on with no fold. I tightend it down and I am still have issues. I guess I will be taking it into the dealer next week.
I really do not think its the cats. Those codes are comming from before the CATS not after. I have already had my CATS replace and the codes for that fix were (System Inefficent) NOT (System Lean). I look foward to your findings. If it was Zero degrees outside I would be all over it
Old 01-19-2009, 05:35 PM
Well I have 85K miles on my truck.
This weekend I put my truck on my father in-laws SnapOn Scanner and went throught the whole engine. I could not get it to thow a code for me while it was plugged into the truck. I went through all the injectors and checked for any history of misfires and misfires while running. So that was good news. I left my In-laws house and was getting 7.5mpg. I decided I should change my airfilter. Supposedly the air filter is rated for 100K. But I went ahead and replaced it this weekend. $60 at Autozone. Gas mileage is back up to normal. Truck is running VERY good. My old filter was pretty bad. I could even tell a weight difference when holding the new vs. the old.
Might want to check your filter.
Old 01-20-2009, 03:35 AM
Well CE light is on again.....I give it its dealer time.
