Old 01-08-2009, 04:49 AM
L2C L2C is offline
L2C is on a distinguished road
Default Changing to 2wd
Has anyone ever done a conversion where u get to switch from 2wd to 4wd
Old 01-08-2009, 05:07 PM
Desert Dan's Avatar
Default Re: Changing to 2wd
Why?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 01-08-2009, 11:00 PM
L2C L2C is offline
i just want to be able to sitch back and forth
Old 01-09-2009, 02:03 AM
CONRAD II's Avatar
I don't think there is any way of adding the ability to change between 2wd and 4wd on the H2 without changing the entire transfer case. However, I did run my h2 for three or four days without the front drive shaft connected. It was just after I installed the 4l80e conversion and my front drive shaft was being cut for proper fit. Anyway, I HATED the way my truck felt without 4wd. Even though the engine ran fine and the tranny shifted properly it still felt very sluggish. Also, FYI it was no faster in 2wd than 4wd.
66' VETTE STINGRAY
07' Z06
Old 01-09-2009, 04:41 AM
Yes, there is a way.
Buy a Tahoe!!
If you do the Durmax/ Allison conversion, you can do this. You get 2wd to 4wd.
In other words you need a new transmission, t case, and bunch of other BS...just to switch out fo 2WD. Seems like a waste to me.
Why would you want to switch out?
Old 01-09-2009, 03:10 PM
brad_p's Avatar
brad_p brad_p is offline
Yeah dump idea to switch out, i cant stand driving 2wd trucks since im so use to driving in 4wd all the time. Dont have to worry about fishtailing or tire spinning.
----------o-o-o-o-
[[_]|[]|[][___]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
Old 01-09-2009, 04:43 PM
There's a few people I've heard of that installed the transfer case, harnesses and such to have the ability to transfer from 2wd to 4wd.
I never did hear about if it affected their gas mileage or not... I can only assume it helped.
And as far as actually turning the H2 into a 2wd without any 4wd ability, that would definitely be a waste IMO.
I bought my wife a new Jeep JK and purposely bought a 2wd for her. a) figured she ain't going off-road anyways and b) just how many parking lot stops could she drive over?
Point is, it sucks. If I knew it was like this, I would have bought her the 4wd.
Mark
Old 01-09-2009, 08:01 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Originally Posted by timgco
Yes, there is a way. Buy a Tahoe!! Why would you want to switch out?
Maybe he just wants to burn rubber and smoke those rear tires!
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 01-09-2009, 08:47 PM
Desert Dan's Avatar
After having full time 4WD for while I would prefer to have a manual t-case that I could switch to 2WD when I wanted to and have manual control over low range rather than an electric solenoid.
Sometimes it is nice to be able to break the rear tires loose
Some Cherokees had a 2 WD and fulltime 4WD choice on the transfer cases but it was manually controlled
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 01-10-2009, 01:02 AM
SummitUp's Avatar
Your right. I have a Jeep Cherokee. The fulltime 4WD was only available on the older Cherokees with the automatic tranny and it was called the Quadra Track system. A separate handle on the center console allows manual selection of 2 wheel Hi, 4 wheel fulltime (can be used on hard pavement0, 4 wheel part time (for off road), and 4 wheel low range.
Old 01-10-2009, 01:50 AM
L2C L2C is offline
yeah that's what I want to do. Is it possible
Old 01-10-2009, 03:22 AM
Well, if that's the case:
Put a Magnacharger on there, and you can smoke all four tires!!!!
It would be way cheaper than swapping out Tcases and such.
http://www.youtube.com/watch?v=qHP1MIfHAEw
Old 01-11-2009, 09:55 AM
Basic idea as to how to do it the least expensive way is to buy a manual tranny, transfer case, and some alterations of other parts. Buy something out of same year 3/4 ton GM truck. Your 2 to 4 shifter will come up tight next to middle console but, causes no gas pedal problems. There is room on left to install a clutch pedal bracket etc. The tranny shifter will fit right in the space where the auto shifter was.
I'm assuming it could be done with auto tranny but, if I were going to do it I would only do it to get manual tranny and look at a 6 speed with short throw shifter.
Once others showing SUV's catch up to the wild stuff Dragon and I have done it is my plan to go this route to set us out front again. You get lot's of points for true custom and especially one of type stuff. We keep small goals lined up out in the future to try and be different as well as ahead. So for shows would be the main reason I would look at but, if you could get a 6 spd tranny in 2wd it would improve mpg allot.
TAZ
