Old 01-24-2009, 12:52 AM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
Default burnt bulb??????
Ok went out to truck after work today and found I had no rear lights on left side of truck. No bumper light, no regular light and no left side marker light? Is this a bulb out to make all these not work? Directional work fine and brake?
Old 01-24-2009, 01:34 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: burnt bulb??????
There is a connector for all the lights for each side under the left rear of the truck. Check and make sure it is fully seated
Old 01-24-2009, 03:17 AM
WHOSNEXT's Avatar
connector seem fine,bulbs and fuses are good, when i press on the brake the side marker light comes on? anything else i can check?
Old 01-24-2009, 06:25 AM
HUMMERICH23's Avatar
HUMMERICH23 HUMMERICH23 is offline
HUMMERICH23 is on a distinguished road
I just had the same thing happen to me the past month and just got if fixed this week. I noticed a month ago which means it might have been out longer the left tail light and regular light out but my top rear roof lamp was still working. I went to the dealer and they replaced the bulbs in each lamp and worked fine for like 1 day then they flickered and burnt out later that day. Took it back and they said it was a faulty wiring harness and something else so they replaced the wiring and bracket for each the tail and regular light. Now it works fine. I dont know if its the same thing going on for you but i got mine fixed and covered under warranty .
Old 01-24-2009, 03:04 PM
WHOSNEXT's Avatar
thanks for the info, made a appointment with dealer today.
Old 01-24-2009, 08:01 PM
Bimmer9938's Avatar
It's the fuse under the hood, not in the dash. Had the same thing happen.
Old 01-24-2009, 08:06 PM
WHOSNEXT's Avatar
will check it out today ....thank you....do you member which fuse?
Old 01-24-2009, 08:10 PM
Bimmer9938's Avatar
Sorry I dont, It was driving me nuts! I had no idea there were two fuse boxes and I kept checking the fuses on the side of the dash, over and over...
Old 01-24-2009, 08:11 PM
Bimmer9938's Avatar
Just turn on the lights and check the tops of all the fuses with a test light, took me like 10 seconds to find it.
Old 01-24-2009, 08:43 PM
Mark805's Avatar
Mark805 Mark805 is offline
Mark805 is off the scale
I get this problem every so often and its always the 10amp fuse in the engine compartment. I think if you look at the cover its labeled LH.
Mine started when I modified my license plate holder / light.
08 H3 ALPHA Carbon Black
Dear GM: PLEASE SELL ME AN HX
Old 01-24-2009, 08:46 PM
Bimmer9938's Avatar
Me too, I replaced the fuse just once and never a problem again. Maybe re check your ground?
Old 01-25-2009, 04:53 PM
WHOSNEXT's Avatar
thats what it was, but now i have another problem once i replaced it? when lights are on my left side rear blinker dont dont work? top break light stays lite? when the lights are off everything works fine? WTF seems there is a short in the left rear running lights?
