  #61
Old 01-26-2009, 04:49 PM
DuckTruck DuckTruck is offline
DuckTruck is on a distinguished road
Default Re: 2 Inch Lift on H2.
Here are the communications I had with Rick via email:
"give me a shout when you have some free time...I will always make time to talk HUMMERS...now more of a sickness than a hobby, I'm a HUMMER owner for life!!!
Rick
rick,
what size tires are you running...especially in width?
the iroks i am looking at are 13.50 wide.....do you think i will have
any problems with that width on my stock wheels with rubbing?
thanks again,
jdj
Jonathan,
I'm running 39.5 x 13.5 Iroks on stock wheels...as I mentioned, in the front, they rub on the swaybar at full turn...
The rear lower control arm pocket at the frame has about a 1/2" to 3/4" stiffening flange below & in front of the bolt hole...I've ground away the extra material to extend only 1/8" to 1/4" out from the face of the control arm pocket...The extra clearance made me feel more comfortable that I would not rip out the sidewall at low pressure...You don't want to grind it flush, because that may weaken the pocket itself.
The other option that I am toying with is to add 1/4" to 1/2" wheel spacers, giving you a little more room...problem with that, is any more than 1/4" spacers & you'll need longer wheel studs...
One other thing that I failed to mention during our phone conversation...I'm using Fab-Tech tie rods because stock ones are so weak...and x-tra suppout brackets on the Idler & Pitman arms to give them a little more life...
I'll see if I can send you a bunch of pictures in a couple of days or so...
Talk to you soon...I hope that info helps!
Rick
Thanks man.....great info.
JDJ
Rick,
Wanted to follow up and ask you another question......
I am almost 100% confident that I will be installing Cognito Motorsports leveling kit (2 - 3") when purchasing new tires. I also 100% certain that I will be running 39.5 x 13.50 x 17 IROKs on my stock wheels.
The question comes when trying to decide between radial and bias-ply. I do a great bit of highway driving, but have run bias-ply tires before (the 37" boggers I told you about).......it would normally be a hands-down decision, go radial. But I am worried about killing my (already lack of) power. Thus, the weight difference between the bias (84 lbs.) vs. the radial (99lbs.) really concerns me.
What do you think about this? Also, how do your bias-ply 40's do at highway speeds, etc.?
Thanks again buddy,
JDJ
Thank you.
I'm just concerned that when stepping up to 39.5's that my highway cruising will suffer even more than when stepping up to 37"s (ie the constant "transmission kick down" that we all so dread!).
Any input on this issue? How does your truck respond?
JDJ
Jonathan,
I had 37's on the truck from the time it was 2 months old...I didn't notice much difference in vehicle performance from stock, as far as mileage/transmission shift points/power. When I added the 39.5's the road noise increased substantially & the trans stayed in low for slightly longer (slightly slower acceleration)...as far as steep hill climbs, I manually shift the transmission, especially when towing up steep grades, so I wouldn't know about the kick-down pro's & cons...There is a way to re-program your shift points if you need to...
I'm in the process of modifying my 2007 to be just like the 2005...including the 39.5 Iroks!!!
I love the bigger tires...with the snow here in Michigan, the 2" body lift & the bigger tires make for a better drive in the country for me.
I got my 07 buried in a snow drift about two weeks ago...The 05 with the lift & tires had no problem with being stuc...I mean "Temporarily detained".
Best of luck with your modifications...Happy new year, hope to see your rig completed some day!
Rick"
There ya go,
DUCK
2003 H2, Lux & Adv Packages, Cognito 3" front suspension lift, Gobi Stealth Rack w/ Ladder, Navigation, twin Optima battery setup, AirRaid Intake, Granatelli Mass Air Flow Sensor, Flowmaster Big Block II Exhaust, Diablosport Predator Programmer,Cognito Pitman/Idler Arm Kit, Fabtech Tie Rods, Rancho RS 9000 shocks, Warn bumper and 9.5x winch, Warn light bar, PIAA's everywhere (14), everything blacked out, and rollin' on 39.5" Super Swamper IROKs on black powdercoated stock wheels.
Old 01-27-2009, 04:48 AM
Tomp,
Thanks, I just happened to read your response.
Tomorrow I will unbolt the bottom of the shock. Just to make sure I understand, you want me to compress the shock so the bottom bolt hole in the shock goes higher than the bolt hole in the extension, correct?
I will do that tomorrow but I did notice that the spacing between the bump stop and control arm is about 1/4". Is that correct or no?
If I can not raise it higher than the shock extension bolt hole, can I buy longer H2 shocks?
Thanks for your help,
Mark
Originally Posted by tomp
Warning: the shock extensions I have seen are too tall for OEM length H2 shocks. To test this, ensure vehicle is on level ground at stock ehight in the front and resting on the bump stops, disconnect the bottom of the shock and see if you can push it up higher then where it would mount to the shock extension bracket. If you can't push it up where the shock's bolt hole goes up higher than the hole in the shock extension, you are either riding on a bottomed out shock if or slamming down on a bottomed out shock when the front end comes down on the bump stops. The latter is the case if you have cranked the TBs. This is true with all H2 shock extensions that I have seen to date. Yes, this is another mark against Truxx.
The reason this is a problem is because these companies assume the H2's shocks are the same as the 2500HD pickup trucks. The shocks are not the same and only have half of the travel that the 2500HDs have.
To correct this problem you must determine the proper amount to shorten the shock extension (to get your shocks into the right range of travel) or use the 2500HD shocks.
The reason the H2's have less travel is because they have extension and compression bump stops in them where the 2500HD shocks only have extension stops. This takes some of the travel away.
Here is the way you need to think about it: Consider the fact that you are pushing up the bottom of the shock much higher than you would be when at factory height and resting on the frame mounted stops.
If anyone doubts what I am saying here, call Rancho and ask them why their online Shock Specifications show H2's shocks with 2.5" of travel and the 2500HD has 4.6". You can also see in this same manual there is a symbol next to the H2's shocks in two places. This "cross" symbol is shown for both compressed length and extended length. This shock symbol is there to inform you of the included bump stops. Notice the 2500HD shocks only show the symbol once?
Also, for those of you thinking it is okay to rest on the stops - think again. Your shocks will start degrading very quicky as you are beating the heck out of them. I went through several sets of shocks and my ride quality went horrible fast - compared to a new vehicle. This was the cause of it!
BTW, my ride quality with torsion bars cranked is much better than stock now
Old 01-27-2009, 05:33 AM
tomp's Avatar
tomp tomp is offline
Hey Mark...you really need to assume that the shock will also need to raise up beyond that 1/4" of space in addition to it raising up above the bolt hole in the shock extension. You also have to consider that bump stops compress when all the weight of your front end comes down hard on the stops. Please take that into consideration.
Yes, the Cognito-Bilstein shocks compress to that of the OEM shocks, plus they are longer for the needed droop required after cranking the TBs.
If the above testing proves that you are bottoming out the shocks, you can still use the shock extensions by switching to the shocks for a 2500HD which are the same extended length as the H2 OEM shock length, plus they compress shorter.
Old 01-28-2009, 02:53 AM
Man, I appreciate your input. Before I start all this, I'm looking into another lift kit. The reason is because by the time I buy control arms, new shocks, I'll have 1200-1400 bucks in it. If I'm spending that much because of a levelling kit, I'd just as well be better off buying a smaller suspension lift kit. Thoughts/opinions?
Like I said earlier, I didn't want to get a 6" kit simply because that will require taller tires, gears, etc, etc.
....unless of course, I can install a 6" and lower it a bit? Is that possible? I'm assuming that a 6" kit is with the torsion bars cranked up to a certain amount.... what if you didn't crank them that far? Is 6" the minimum you could go?
I talked to a dealer for Cognito and he said they made a 4" kit for the H2.
I looked it up and didn't see anything but did see a 4" kit for an HD2500. Are the front suspensions the same?
Thanks again,
Mark
Old 01-28-2009, 02:56 AM
I bet the "4 inch kit" he is talking about is the 2-3" kit we are speaking of.
Other option would be to run the Rancho, which is a 4" lift you can crank to 6"......but the difference between these two is about a grand PLUS installation (which will be large for the Rancho).
DUCK
Old 01-28-2009, 04:01 AM
Just out of curiousity, does anyone know anything about the Rancho suspension? I swear I read that they had a bump steer problem.
Anyone know?
Thanks,
Mark
Old 01-28-2009, 04:11 AM
Bimmer9938's Avatar
The Rancho looks like a nice kit, there was a guy on the forum with a green H2 who had it.
Old 01-28-2009, 04:12 AM
Bimmer9938's Avatar
Anyone know?
Thanks,
Mark
Mark, you already want to go bigger?? LOL.
Old 01-28-2009, 04:22 AM
I have to. I made a 1000 bet that I wouldn't supercharge it for the first year.
LOL.
Mark
Old 01-28-2009, 04:29 AM
Bimmer9938's Avatar
Your my hero!
Old 01-28-2009, 05:34 AM
OC,
I think the more research you do re: the Rancho kit will lead you right back to the Cognito kit or a setup like Tom.
DUCK
Old 01-28-2009, 06:21 AM
tomp's Avatar
Mark, all you need to do is take verify the shock extension brackets are not too tall. They most likely are too tall and if they are, they can be easily modified.
Thanks again,
Mark
Old 01-28-2009, 10:02 PM
That was me.
http://www.elcovaforums.com/forums/s...ad.php?t=22707
RuggedH2 now has that truck and improved on the kit as well. He'll have to comment on what he changed up.
I can tell you that this kit is expensive though. The kit is listed as a 4", but did add 6" without the additional height of the tires. You cannot use the stock rims either.
The only things I did not like about the kit:
Teh Tbars do hang down below the frame...but with the added height
isn't too big of an issue.
The kit is not reversible. You're not going back to stock...ever...well at least without welding.
the rear drop brackets (I think Rugged addressed this though) did hang down quite a bit.
As far as ride quailty and highway speeds, that kit handled great. But with adding this kit, ther are other things to consider: steering stabilizer, idler/pitman support, Hd Tierods are all not included in this kit and added to better handling too. I did not add the support kit on that one though.
Old 01-29-2009, 02:55 AM
Guinnessboy Guinnessboy is offline
Guinnessboy is on a distinguished road
ive got the ultimate lift....its called factory...STOCK!
Old 01-29-2009, 03:44 PM
Old 01-29-2009, 09:48 PM
Originally Posted by DuckTruck
the guy in the link, rick, and i have emailed and spoken on the phone about his setup. he is super helpful and truly has a bad ass rig.
oh....and he has his own, custom made 2" body lift and IS running 39.5 bias ply IROKs.
doable.....i think so; there is your proof.
DUCK
Can we see pics of this truck doing some serious wheeling?
Albie has a 6" Fabtech with 40's and his rubs like a teenage boy getting his first peek at Penthouse.
We had 38's and they rubbed bad as well.
Put them on and see what happens.
Old 01-29-2009, 09:51 PM
That is truly the funniest way I have ever heard to describe a tire rubbing after lifting a vehicle.....damn, I blew coffee all over my laptop.
DUCK
Old 01-29-2009, 09:53 PM
Bimmer9938's Avatar
Are you sure that was coffee....were you also looking at the Hummer and babe thread too?
Old 01-29-2009, 09:56 PM
Haha.....I'm sure it was coffee!
Old 01-29-2009, 10:01 PM
Bimmer9938's Avatar
All we had when I was a teen was the Sear's catalog and National Geographic, thank god Victoria Secret came out with a catalog!
