Old 02-04-2009, 08:04 PM
AK47's Avatar
AK47 AK47 is offline
AK47 is on a distinguished road
Default fabtech tie rods
Hi All
Listen i have been looking for a upgrade tie rod kit for my H2 as i have big boots on it it of course puts a strain on things now i found this ,,, http://www.car-stuff.com/carparts/hu...002113454.html now even i have recently replaced them i thought this would be a great kit to have ,, now i have one point i need to raise ,,will these fit,? as it says only with fabteck suspensions ,,can anybody tell me if it would fit if i dont have the fabteck suspension ,
cheers
Grant Ryeback
www.euroco-corp.com
http://www.hummertruckworld.com/EUROCO/
00423663114587
Old 02-04-2009, 08:09 PM
LEcustoms's Avatar
LEcustoms LEcustoms is offline
LEcustoms is off the scale
Default Re: fabtech tie rods
From what I have been reading they will fit on non lifted truck. I might have misunderstood. If i did someone please correct me. If you do get them trail duty sells the same thing for alot less. Here is the link. http://www.trailduty.com/product_info.php?cPath=112_118_120&products_id=109
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
Old 02-04-2009, 08:13 PM
AK47's Avatar
Hi there well all helps ,,,lifted well not really i only have the TRUXXX front leveling kit on i dont think counts ,,maybe helps ,,,lets see i am sure someone can give imput to this
cheers
Grant Ryeback
www.euroco-corp.com
00423663114587
Old 02-04-2009, 09:04 PM
LEcustoms's Avatar
I hope the truxx counts cause all I have done for the front suspension so far is the greens keys and was looking at getting these tie rods eventually too.
03 White H2
06 kawasaki stx-15f
02 yamaha superjet
Old 02-04-2009, 09:11 PM
AK47's Avatar
ok well i am sure we will get help on here
Grant Ryeback
www.euroco-corp.com
00423663114587
Old 02-04-2009, 10:17 PM
Boss Hoss's Avatar
Boss Hoss is off the scale
Many stock rigs run the Fabtech tie rods. Back in the day when the site was full of people who wheeled their rig, most upgraded to the Fabtechs. I have been running the Fabtechs personally with 0 problems. In fact if you wheel i feel they are necessary.
Old 02-05-2009, 12:24 AM
RippSpeed RippSpeed is offline
RippSpeed is on a distinguished road
but will they work with leveling kits ??? I think they should
Old 02-05-2009, 12:38 AM
Better hope they work. I just received a set last week that I haven't installed. I only have the Truxx kit on mine right now.
I used these same tierod ends on my lifted H2 and had no problems with them. To me, it's a first mod kind of thing.
BTW, if you do want to buy them, you can find them for 35 bucks cheaper on ebay. I only paid 249.
Mark
Old 02-05-2009, 12:57 AM
splne1's Avatar
splne1 splne1 is offline
You have to purchase a sway bar extension from what I read on the ebay auctions. It tends to have a possibility to rub on the sway bar.
Old 02-05-2009, 01:37 AM
Wink Re: fabtech tie rods
I have the fab tech tie rods with the ready lift kit which is the same as the truxx kit and the green key kit and they work fine.
i do not have a swar bar extension and i have had zero problems for 2 years 4 months.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 02-05-2009, 04:49 AM
tomp's Avatar
tomp tomp is offline
Fabtech states this because there is risk under a binded steering position, that the large inner tie rod joint can bind against the sway bar. When there is stress on the centerlink, the curved ends tend to cause the centerlink to twist upward due to geometry of this curve in the centerlink. To control this "twisting of the centerlink" (which also causes premature wear of the pitman/idler arms, I might add) the Cognito Pitman/Idler support kit is highly recommended. This Cognito kit will actually keep stock tie rods from breaking so easy due to the nature of it controlling the centerlink from twisting - which in turn keeps the tie rods from getting into a binded position. I suggest this kit even before upgrading to HD tie rods!
Once you have both kits (HD tie rods and Cognito P/I arm kit), the next best thing to do is to get the Cognito OEM length sway bar end links. They are called OEM length, but are 1" taller then the OEM links, which allows more clearance between the HD tie rods' inner joint and sway bar.
The other good thing about their end links is they incorporate a swivel link for the lower control arm. This is perfect for those with the Truxx kit or any other scenario of cranked torsion bars. When you crank the TBs with any of the methods out there, the lower control arms are now at a more severe angle and the sway bar link geometry is now "off". This swivel corrects the geometry to compensate for the cranked up torsion bars. They are also better quality and more HD than the OEM links. Very good mod for the price!
Old 02-05-2009, 04:52 AM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
The reason Fabtech won't endorse their tie rods for H2's is because the inner rubber boot will only clear the sway bar by about 1/8 inch in a full lock turn. The boot can actually be torn when turning hard while off-roading. Dozens of H2 owners run Fabtech's with no problems however.
This pic tells the story:
The cure for this situation is to replace the sway bar links with Cognito sway bar links. They're longer than OEM and will give about 3/4" clearance:
Interesting thread on Fabtech vs. Cognito tie rods <Here>.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 02-05-2009, 04:57 AM
SummitUp's Avatar
Dang it Tom! You beat me to it!
Old 02-05-2009, 11:58 AM
AK47's Avatar
Well i awake to find amazings detailed replies ,you guys fail to amaze me thnks for all your help and input ,
Now the big question can you recomend who what and where i can buy these parts ,,the issue i have as many other european memebers have nobody wants our money
Grant Ryeback
www.euroco-corp.com
00423663114587
Old 02-05-2009, 01:53 PM
tomp's Avatar
Finally...LOL. You beat me on most all the rest of them!
Old 02-05-2009, 03:25 PM
SummitUp's Avatar
Hardly! I think you wrote the book on most of this stuff!
Originally Posted by AK47
Well i awake to find amazings detailed replies ,you guys fail to amaze me thnks for all your help and input ...
We fail to amaze you!? Man, what does it take to amaze you!?
I would contact Phil at trailduty.com. He's a moderator at w-w-w-.h-u-m-m-e-r-x-c-l-u-b-.c-o-m (take out the dashes), he's from the UK and I think he would help you out. If your a member over there, you could PM him directly, or just call the phone number on the Trailduty website and ask for Phil. Tell 'em SummitUp sent you!
Old 02-05-2009, 03:37 PM
AK47's Avatar
yeep sounds good i have sent a email
Grant Ryeback
www.euroco-corp.com
00423663114587
Old 02-05-2009, 07:12 PM
tomp's Avatar
X2 on Phil at Trail Duty!
Best prices, shipping and support!
Old 02-05-2009, 07:15 PM
tomp's Avatar
Hey Summitup, you get them spacers installed okay? Never heard back...
BTW, I need to update my signature - looks like you are starting to catch up
Old 02-05-2009, 08:04 PM
SummitUp's Avatar
I never got back to you because I've been without internet access for the last 2 weeks! My ISP is a small wireless internet provider (WISP) up here in the mountains, and one of their repeater towers got damaged by the high winds we've had recently.
I just sent you a PM (from that "other site" ).
Man, I doubt I'll ever catch up with you!
