Old 05-04-2006, 01:41 PM
rudy8266 rudy8266 is offline
rudy8266 is off the scale
I was thinking of buying a cold air inake, i was looking at the Volant, AirAid, and K&N. i have heard good and bad things about putting a cold air intake on the H3. What should I do?
Old 05-04-2006, 01:47 PM
Surferjo Surferjo is offline
Surferjo is off the scale
I would say save your money. The Stock air box on the H3 is not restrictive at all. I don’t think you will see any appreciable gains with it.
Also it will let in larger dirt particles, which is not a good thing for a truck that's going to be spending some time in the dirt.
ITS HERE!!!!
Old 05-04-2006, 02:01 PM
H3 Hummer's Avatar
H3 Hummer is off the scale
Do you want to increase horsepower or MPG? Do you care about extra loudness or not? You may not get to much extra hp but you will feel a difference when you really get on the gas.
Not sure if I agree with the dirt particles statement. Yes, it is open but it is a much better filter. If you put the oil on there correctly it should be just as good as the OEM if not better.
The couple of hundred dollar investment may be worth it to some but not to others.
Old 05-04-2006, 02:03 PM
bparker's Avatar
bparker bparker is offline
not worth the time and money. been there and done that.
http://www.tahoeforum.com
http://www.motoforum.com
Old 05-04-2006, 02:14 PM
phantom2's Avatar
phantom2 phantom2 is offline
phantom2 has a little shameless behaviour in the past
I agree...total waste of money
War is not hell...it's worse
Old 05-04-2006, 02:15 PM
Ok...
To start there is a really large post elseware, just do a search.
But the jist of it is, if you really look your H-3 already has COLD AIR INTAKE. Pull the cover off the air box and you will notice it is fed air from within the right fender area, not the hot air from under the hood. The other concern is the aftermarket ones that use oil on the element "POSSIBLY" can effect your sensors (again search the other long post about this subject)
RYD
