Old 02-12-2009, 04:09 AM
hotstang46` hotstang46` is offline
hotstang46` is on a distinguished road
Default HID Expert Needed for Opinion/ trouble shoot help
So I am in the process of installing HID fogs on my H2 (i've actually been photographing process for a "How To" for ths site). I have encountered a problem that I think may be the bulb. I have a "working side" (driver) and "non working side" (passenger). I have enough mechanical knowledge to know the connections are all correct. The non working (passeger) side will flicker once and shut off immediately when I try to fire it up. I then switched the ballasts from one side to another and the same thing still happened. The passenger side still did not work and the drivers side did. So both ballasts work on the driver and both don't on the passenger. Question is, could the flicker and shutting off be from a bad bulb? My natural instinct tells it's a connection problem but I checked and rechecked and couldn't find anything.
Thanks for anyone's help
Old 02-12-2009, 02:55 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Default Re: HID Expert Needed for Opinion/ trouble shoot help
This is going to sound crazy but check your fuse's. When HID's start they use quite a bit more power than regular bulbs. You could have blown that fuse with the 1st power up. If it's blown or not you should increase the fuse size to be able to handle the initial start up. After they ignite they use less power than regular bulbs so putting in a bigger fuse won't hurt.
Old 02-12-2009, 05:37 PM
Could be a bad bulb, bad internal connection or bad wire splice.
Old 02-12-2009, 06:15 PM
RippSpeed RippSpeed is offline
RippSpeed is on a distinguished road
I have the same problem but I havent chase after it because I've been busy... But its definitly a bad ground...
1) where did you tap the power ???
2) wheres your grounding spot ????
Old 02-12-2009, 08:09 PM
Well I know it's not a fuse. I used no existing vehicle wiring. It's all new. There is one fuse so for one light to be working that can't be it.
At this point in time too, it simply can't be a bad connection. I have tested all of them and have ruled that out.
"RippSpeed I have the same problem but I havent chase after it because I've been busy... But its definitly a bad ground...
2) wheres your grounding spot ????"
power, on the new wiring harness is to the battery (with relay and fuse on the line) and negative is to the battery.
See I'm thinking it has to be the bulb, but I'm just not familair with what signs a bad bulb would exhibit. I know when a halogen goes out it out. No flicker no nothing. Which is why i find it strange that this bulb will flicker once and shut off immediately on initial powerup.
Old 02-12-2009, 08:47 PM
its not a bulb... trust me, I have the same problem...
This is what you need to do to make sure its not a bulb... First you said the driver side works. Now the passenger side doesnt work. Unplug the passenger side bulb and hook it up to the driver side balast and if it works then its not the bulb... It has to be with the power source or the grounding spot ...
Old 02-12-2009, 10:11 PM
did that and the bulb still did not work. Both ballasts function properly when hooked up to the drivers side bulb. Both "power outs" on the wiring harness work when on the driver side bulb. Only thing left is the bulb on the passenger side. It's the common denominator.
Strange thing though, i just went though everything, all new connectors, double checking everything and it seems to be working ok now.
hope it stays working. I'm ordering a new bulb anyways.
Old 02-13-2009, 12:43 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Are both ballasts wired so they each have their own ground and power? If either ckt is wired in series it may be the problem. Not had much experience with hid's myself
Old 05-16-2009, 05:36 PM
lfe136 lfe136 is offline
lfe136 is on a distinguished road
Has any one fixed this... I have the same problem.
Old 05-16-2009, 06:00 PM
yes it can be fixed by buying a capacitor with your hid harness from retrosolution this should fix the problems...
Old 05-16-2009, 07:46 PM
I don't get how this will fix the problem and where do I install it?
Old 05-16-2009, 07:51 PM
the capacitor bumps the voltage of the lights so they would stay on... contact Todd at sales@retro-solutions.com and asking him how the capacitor help with a hummer h2 with day light running light ...
Old 08-05-2009, 01:36 PM
Vark Vark is offline
Vark is on a distinguished road
Did you fix it?
And what kit did you get?
Thanks,
Max
