Old 03-15-2009, 06:09 PM
vandy0090's Avatar
vandy0090 vandy0090 is offline
vandy0090 is on a distinguished road
Default heater issues
so i noticed last night that my passenger side blows full hot all the time. i can pull it down to show 60 on the ac panel but the heat is stays blowing outta the vents. only on the pass. side. the back and drivers vents will all go to cold. anyone have that issue? im guessing i have a stuck valve or possibly a bad heat/ac controller. ????
Old 03-16-2009, 02:17 AM
Default Re: heater issues
Got the same
Old 03-16-2009, 03:37 PM
vandy0090's Avatar
Originally Posted by MONSTERMATT
Got the same
kinda annoying isnt it? not too bad right now since its still a lil on the cold side. and if its nice i can just roll the windows. but im sure it will be gettin warmer soon and ill need the ac with out the heat
Old 03-17-2009, 12:16 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
You will likely need a new right temp door actuator, the hardest one of them all to change. You could get the dealer to try a actuator recalibration with the tech 2 but its likely the actuator itself at fault
Old 03-17-2009, 01:51 AM
vandy0090's Avatar
where can i find this actuator? where abouts it is located?
also do u know how much one runs?
Old 03-17-2009, 04:31 AM
actually iam mistaken, my heat blows cold on the driver side and normal on the passenger side, this only happens if i crank at 90 (it stays hot ) and than when i turn it down and than try to put it back up it wont get hot again until i shut off the engine , soooo i cant turn the temp down and back up again normally, the pass side works fine thou, havent played with th ac yet
Old 03-17-2009, 07:30 PM
HUMTECH's Avatar
The left temp door actuator is the easy one. Just remove the right side ip insulator(plastic cover above passengers foot) and it is just to the right of the center console. I think they run around 100 bucks but im not sure exactly. The right side temp actuator is on top of the hvac unit, under the top of the dash. Difficult to get to but can be done by removing the top dash cover and then get a little creative to access it.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 03-18-2009, 01:36 AM
vandy0090's Avatar
so im guessing with my luck the one under the dash is the one that controls the pass. side heat/air? what are the chances the the control unit went bad? is there anyway to trouble shoot this?
i think we need to set up a paypal fund for you and all the great insight u have into these trucks. thanks again
Old 03-18-2009, 01:55 AM
vandy0090's Avatar
well i found one on gmparts direct. looks like its down to $40.00.. every where else its been around 120 or so...
hey also sorry im askin so may questions... im at work and the truck is at the house and i have very limited time to tear in to her so im trying to cover all my bases.... so u think its possible to have a fude blown that would only be running the pass. side? i know there are fuses for just about every light on the thing. im just wondering if it was on heat (since its been winter) blown a fuse and now it wont actuate. im just not sure if there are 2 dif. fuses for the system... hmmm. ive had a hell of a time with the electrics on this thing... im about to just re-wire the whole damn truck
Old 03-18-2009, 06:54 PM
HUMTECH's Avatar
The one under the dash controls the drivers side heat. No separate fuse for it, when they go bad they typically will default to the hot position. As well if the mode door actuator was bad it would normally default to the defrost position.
1998 Chev Z71
Old 03-18-2009, 06:56 PM
HUMTECH's Avatar
I re-read your post, the one under the dash but on top of the hvac unit controls the right side. the one just above the passengers foot towards the center controls the left side
1998 Chev Z71
Old 03-18-2009, 07:57 PM
vandy0090's Avatar
so i need to replace the one on top of the hvac unit... nice.. well thats the cheeper of the 2 but prob becuase it the one thats harder to get to.. nice... well ill see how it goes... thanks
