Old 04-14-2009, 08:57 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
Default Re: Hummer steps are on...
Originally Posted by Boss Hoss
You can use your stock rocker trim, however the stepping surface will be smaller and i think it looks much nicer with the new trim. You will have to take the stock trim off to get the steps on but your rock rail stays put. When you pull off the stock rocker trim, the clips will break(no way around it) so you will need new clips.
how many clips per side? and does anyone have a part #?
Old 04-14-2009, 11:53 PM
HUMMERICH23's Avatar
HUMMERICH23 HUMMERICH23 is offline
HUMMERICH23 is on a distinguished road
Thank you sooo much, that helps me out a lot. You might as well just install the whole kit instead of keeping the stock rocker cover. I see that the colors arent too far off from the textured black stock to the smooth black.
Old 04-15-2009, 04:14 PM
hummer.dad's Avatar
hummer.dad hummer.dad is offline
hummer.dad is on a distinguished road
I need the part # for the clips as well. If I have to turn mine back in (from lease) I'm putting the factory rockers back on and selling the steps and side rocker. Need to purchase 24 clips once I have the part #.
Old 02-27-2011, 01:11 AM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Originally Posted by hdmlnium
Just wanted to thank Bimmer9938 for the steps and rockers. I put them on this morning and all went smooth. It took me about 2 hours to do the job. They make getting in the Hummer a lot easier now, less wear and tear on the seats as you don't have to slide across to get in anymore.
Anyway, I thought I would add a few pics..
Bill
Love the way that looks! If I hadn't had gone with my AMP's I would've definitely done this.
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 08-20-2011, 10:03 PM
bigmikey82 bigmikey82 is offline
bigmikey82 is on a distinguished road
For those needing the retaining clip part # it is 10297370. I just did mine, but didn't need to buy any clips. I was able to remove the original rocker molding without breaking any clips and they just swap right over to the new rockers.
