Old 05-13-2009, 10:16 PM
toy2h3's Avatar
toy2h3 toy2h3 is offline
toy2h3 is on a distinguished road
Default HArness for New Stereo
what harness do i need for my H3 , 2006 with base system
non bose /non monsoon
i was thinking this Axxess GMOS-01 Onstar Harness Adapter with Chime '02-UP has anyone used this
JD
Old 05-14-2009, 03:02 PM
Default Re: HArness for New Stereo
There are several interfaces around. You only need the chime module if you want to continue to hear the annoying audible alarms...
Peripheral makes interfaces as well. Research around B4 you buy. Call cruchfelds for expert advice and products
Old 05-14-2009, 03:08 PM
toy2h3's Avatar
anyone know if Axxess GMOS-01 Onstar Harness Adapter with Chime will work ?
JD
Old 05-14-2009, 07:15 PM
Rred's Avatar
Rred Rred is offline
Rred is on a distinguished road
I just bought this for my H3. I bought it to go with a new JVC touch screen. These are the products crutchfield suggests. But all you need to do is go to crutchfield.com, put in the info for your truck, find the deck you want, and they will tell you everything you need to go with it. The wiring harness I bought is pricey, but I want to maintain the factory features. You could go with a standard harness for $25. Hope this helps and shoot us some pics when you get your new unit in.
The antenna adapter: $9.99
12040GM10 GM Antenna Adapter Motorola M to OEM antenna
The mounting bracket: $12.99
120953304 GM Kit 2005-Up, DD
The wiring harness to retain the factory onstar and chime alerts: $99.99
120GMOS04 Metra VT-GMOS-04 GM Class II Data bus Interface
06' H3 white/black adv/lux
Blistiens at all four corners, leveled, 35" Toyo M/Ts
Old 05-14-2009, 08:51 PM
toy2h3's Avatar
Thanks will do
JD
Old 05-26-2009, 10:17 PM
toy2h3's Avatar
Stereo in today will post pics later tonight if i have time !
JD
Old 05-27-2009, 03:48 PM
toy2h3's Avatar
JD
