05-05-2009, 03:38 AM
Weird Noise, can you help?
Ok, there is this weird noise coming from the drivers side front tire when I'm turning. Now its only sometimes and when I first startup. Time of the day doesn't matter and after driving for a few minutes it stops. Sometimes I notice it more when turning to the left. Checked underneath and don't really notice anything loose, broken or leaking. Can anyone shed some lights on this??
05-05-2009, 03:17 PM
Re: Weird Noise, can you help?
2:38 am?
What does it sound like??
Hub Bearings?
Diff?
ball joints?
06-03-2009, 03:47 AM
Did you ever find problem ... I have the same thing it is a squeaking noise it is embarrasing
06-03-2009, 04:01 PM
does it sound like a metal on metal creak or cracking?
2009 H2 Silver Ice LE
06-03-2009, 04:57 PM
jack front end up and ck for up/down movement in wheels.
most likely hub(s).
06-03-2009, 08:38 PM
the bearings in the hubs are known to go out , also check that the boots on the front CV's aren't ripped ,if so you may need a new or rebuilt drive axle . new is better .
A government big enough to
you have.
-- Thomas Jefferson
06-05-2009, 07:58 PM
I just replaced my left bearing and it made the exact sound you have descrived.
06-06-2009, 11:14 PM
How much to get this fixed??
06-07-2009, 07:05 PM
I was quoted $500 and $550 here, but I bought the hub assembly @ Advance for $185 and did it myself. 2.5 hours of wrenching to save about $350.
06-13-2009, 01:45 AM
Yep, it was the hub....not too bad...350.00 non dealer...
