Old 06-22-2009, 10:38 PM
allterrainblue allterrainblue is offline
allterrainblue is on a distinguished road
Default Brush Guard Lights
Hi,
This is my first post...and I just recently purchased a 2007 All Terrain Blue H2....love it!
I have purchased a double up OEM brushguard with OEM brushguard lights. I have the wiring harness, but there were no instructions on how to hook it up. I don't know where the connectors go under the hood. I have brown and black connectors, plus two fuses. I believe most people attach the fuses on the outside of the fuse box side....
Any help would be great!!!!
Old 06-23-2009, 11:46 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Brush Guard Lights
The underhood connection is under the fuse box cover. remove the large black plastic cover and you will see a blue wire that is for trailer brakes. disconnect the connector and plug in there. under the dash the brown connector plugs in under the black cover to the left of the brake pedal assembly. If you remove that cover you will see a bunch of empty plugs, i believe it is the 2nd one from the left, i think it only fits in that one anyway. The switch goes in the overhead console and when mounted with on being pushed up, the black wire goes on the bottom tang, then yellow then blue
1998 Chev Z71
2007 Chev Trailblazer SS
