Old 06-24-2009, 03:08 PM
vandy0090's Avatar
vandy0090 vandy0090 is offline
vandy0090 is on a distinguished road
Default mystery leak
so ive had this h2 for about 2 years now and ive had a mystery leak on her for about a year and a half. its coolant drippin off the scrape plate. its not there all the time.. mostly in the mornings. maybe 3 days a week there will be a little wet spot under it. ive looked sevral times for it but like i said it comes and goes. any thoughts on where to start looking. from what i can tell all my hoses are good and have no tranny leaks..
Old 06-24-2009, 03:25 PM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
Default Re: mystery leak
Should be a small leak at the head gasket. On a rack you can see if the leak is coming down and settling on that skid plate. That will give you your answer. Thanks....
Old 06-24-2009, 04:04 PM
tomp's Avatar
tomp tomp is offline
If it's on the passenger side, it is probably the condensation line that is for the air conditioner.
Old 06-25-2009, 01:22 AM
IRA51's Avatar
IRA51 IRA51 is offline
First make sure it is coolant, if it is ,clean the engine and frame and skid plates ,than wait till it leaks again and follow the path of the leak . Dexcool is easy to spot .
A government big enough to
you have.
-- Thomas Jefferson
Old 06-26-2009, 06:18 PM
vetteSUT's Avatar
vetteSUT vetteSUT is offline
vetteSUT is on a distinguished road
put down some paper towels and see what color they are the next day.
Old 06-27-2009, 01:24 AM
IRA51's Avatar
there is no way you could mistake Dexcool .
you have.
-- Thomas Jefferson
