Old 07-24-2009, 07:15 PM
HummerRidin26"kmc's HummerRidin26"kmc's is offline
HummerRidin26"kmc's is on a distinguished road
Exclamation steering upgrades
ok i have 26"s on my hummer at first they helped the steering but now i feel like they have basically wore my steering out an i was just wondering what you all think i should do to upgrade my steering components to make it steer better than new iam gonna start with new idler arm pitmanarms inner an outter tie rod ends but besides that in there anything else to help improve thanks for time
RickyFNRoss
Old 07-24-2009, 07:34 PM
Lotusman333 Lotusman333 is offline
Lotusman333 is on a distinguished road
Default Re: steering upgrades
Having 26"s on your H2 increases the stress on the idler arm and tie rod ends especially. It could be that you've weekend these over a period of time there for your steering pump may be having to work harder. I may have alright caused harm to the pump, i couldn't say for sure since I've never seen your car. I would recommend replacing/upgrading those parts in particular the other ones you listed are optional but would also be helpful if upgraded. Then if it's still giving you trouble, you probably have damaged the pump and would need to simply replace it.
Note: You shouldn't have to upgrade the pump in any way, as long as you upgrade those parts that go with it then that should take all strain away from the pump and not cause damage again.
Old 07-25-2009, 06:55 AM
Here's my suggestion towards building a better handling H2. It sounds like your steering got loose. The pitman/ idlers will go fast with heavy wheels like that. Many of us that wheel replace these more than we like. So to correct the issues at hand, and upgrade to a more realiable/enjoyable H2:
ADD:
*Cognito pitman/ idler support kit $216
*Cognito Idler Pivot kit $200
*Rancho steering stabilizer $55
*Fabtech Tierods. $225
*Change out factory shocks. Rancho 9000's are nice and adjustable to your taste $400 for the set of four
* Edelbrock Panhard Rod $125
* Edelbrack Rear Trailering arms $340
These will all improve your ride/handling and help with all that added weight those wheels added on the front end. I would start with this list first. You will notice a night and day difference!!!!
At some point, you may want to look into a BIG Brake kit. Brembo has nice kit but very pricey.
Good luck.
Old 07-26-2009, 05:02 PM
thanks for the suggestions yea speaking of the shocks i just bought the rancho in cab adjustible kit wit the 9000s its pretty amesome makes the ride amazing
RickyFNRoss
