Old 09-01-2009, 09:00 PM
HummerRidin26"kmc's HummerRidin26"kmc's is offline
HummerRidin26"kmc's is on a distinguished road
Default RIGHT FRONT TIRE WEAR???
alright basically i have ruined two diffrent toyo proxies with in ohh 9 month period i have had 4 alignments within that period my truck has 26" wheels is why i have had four alignments to prevent tire wear yea well my truck seems to continue to just ruin my front right side tire the wear is on the outter edge of the tire basically i was wondering is there some type of suspension problem that can cause this to continue to happen almost like the truck cant hold an alignment even though it drives striaght an everything yes i have had steering issues aswell Tie rods an the rest of the usual stuff pitman arm idler arm ect that stuff has been replaced and fixed yet still wearin the right front tire out any help thanks for ya time
RickyFNRoss
Old 09-01-2009, 11:39 PM
[__--MUD--__]'s Avatar
Default Re: RIGHT FRONT TIRE WEAR???
cranked up t-bars?
I'd go to a different alignment shop. I went through 3 before I found one that knew what the hell they were doing. First 2 said they had everything all aligned and setup.
Old 09-02-2009, 11:23 PM
H2illBilly's Avatar
H2illBilly H2illBilly is offline
H2illBilly is on a distinguished road
Have you checked the ball joints? If your wheels are "deeper" than stock wheels, Your ball joints will wear out faster.
Old 09-06-2009, 05:14 AM
lx4life lx4life is offline
lx4life is on a distinguished road
Originally Posted by [__--MUD--__]
cranked up t-bars?
Would cranking the t bar make differnce, even with an alignment?
Old 09-07-2009, 12:30 AM
HMH2SUT HMH2SUT is offline
HMH2SUT is on a distinguished road
Bad wheel bearings...... change them and have a different shop align it and you should fine.
Old 09-07-2009, 01:13 AM
If you got an alignment after you adjusted them then no.
Problem is you think a shop is going to tell you they couldn't align your rig properly? I went through a number of shops before I found a knowledgable mechanic that knew what the **** he was doing..
Any good shop should of been able to identify a bad wheel bearing before doing an alignment...
Old 09-07-2009, 07:35 PM
with mud. After Installing the fabtech tierods, I knew my bearings where shot but that was next weekends project... anyway i took it for an alignment at a shop Close by but had never used, just to see if it was close after the install... They said nothing about my bearings but did try to sell me an oil change.
