Old 09-21-2009, 11:32 PM
h2con h2con is offline
h2con is on a distinguished road
Default Time to replace my front brake pads, is it a diy job?
I have changed brake pads on a few cars and trucks myself in the past and was wondering if the H2 is also a job I can handle in my garage? I never did any with ABS? The rotors are smooth except one front has a hair line groove in it. Should it be turned with one tiny groove around it or can I get away with that?
Old 09-22-2009, 12:41 AM
LEcustoms's Avatar
LEcustoms LEcustoms is offline
LEcustoms is off the scale
Default Re: Time to replace my front brake pads, is it a diy job?
Its not hard at all if you have some experience. Just unbolt the wheel the caliper, press in the caliper piston grease all guides and the pin slide in the new pads and bolt everything back up. There are more steps thats just a brief run down. If your doing brakes get both rotors cut it doesnt hurt and everything is apart anyway. I always get my rotors cut when I do a brake job. Costs like $15 bucks and your good to go. Just my opinion.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
Old 09-22-2009, 12:55 AM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
My two cents is that due to the REALLY long life of the brakes on the H2, may be worth just changing the rotors out when you do the pads.
Old 09-22-2009, 04:36 PM
HumminNBoatin''s Avatar
I agree with Luv2Camp. Take the rotors off. Go to the parts store and have them measure them to see if they can even be cut. Odds are they are no longer in spec. Just depends on how many miles you have on them.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 09-22-2009, 04:58 PM
I'm the original owner since new. Its a 03 with 48,000 miles.
Old 09-22-2009, 07:50 PM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
You should get twice that mileage. Are they squealing at all?
Old 09-23-2009, 01:03 AM
I bought my new pads today and took the front wheels off to start the install. Now that I could get a good look at the pads, they where in great shape. I was thinking it was time to replace them but I was wrong. mbdougl they do squeal every once in a while, but very rare.
Old 09-23-2009, 01:07 AM
IRA51's Avatar
IRA51 IRA51 is offline
You should cut or replace the rotors when doing a brake job.
it's all about the friction .
A government big enough to
you have.
-- Thomas Jefferson
