Old 10-04-2009, 10:39 PM
kmleong kmleong is offline
kmleong is on a distinguished road
Default 2004 H2 Lux Bluestar Install
Finished mine yesterday. Here's what I found, hope this can help someone
1) Remove console lid
2) Remove bucket and 3 bolts underneath
3) Shifter to 1st, loosen set screw on front of shifter. Shift to neutral and lift straight up to remove
4) Cup holder and PRN assy. come off by lifting straight up. Held on by 3 friction clips. 1 front center, 1 on each side toward the rear
5) Remove bolt beside shifter assy. and 2 hex head screws from front of console. 1 on each side of front friction clip,underneath, facing forward
6) Remove 2 hex bolts on the center bezel. 3 friction clips front/top, 1 on each side /approx 1/3 up
7) Lift and slide console back enought to remove center bezel
8) Unbolt Onstar Module
9) Remove glove box
!0) Unplug 2 white sockets from Onstar, seperate foam tape and rout them to the right. Toward the glovebox
11) Bluestar will go up in cavity under airbag switch. Circuitboard,up,horizontal,plugs toward center. I zip tied mine to horizontal brace. Bluestar sits on top of brace
12) Revere procedure to put everything back
My troublepoints; Dropped socket when installing front screws on console.
It rolled underneath shifter.
3 friction clips holding PRN assy launched off
somewhere on reassembly. Have to replace them
Paired up my Blackberry and it works perfectly. Just like a landline.
Led doesn't light up when you press red button to adjust volume, but it works anyway to adjust volume. Hope this saves you some time if attempting this install. I took off way too much for nothing
2004 H2 Lux; Night vision, Helix Tower power 11, Volante CAI, Diablo Predator, Bluestar, 20" Weld Racing, 325/60 Terra Grapplers, Rancho 5000's + Steering Stabilizer, XTC Lightbar,Hella driving lights, Compustar Alarm + Remote start, 2 Elec. fans, Tru cool 4739, oem Rear camera,console vault
Old 10-22-2009, 11:00 PM
pohlease pohlease is offline
pohlease is on a distinguished road
Default Re: 2004 H2 Lux Bluestar Install
Thanks for taking the time to post this.
