11-03-2009, 12:36 AM
`08 mirror on `03 H2
does anybody have a wire diagram that showes how to wire a 2008 driver side mirror to a 2003 H2?I know that the end plugs are differant on the `08 mirror.So any help would be greatly appreciated.
11-03-2009, 02:39 AM
Re: `08 mirror on `03 H2
I sent the the schematics and connector end views in a pm. Did you not get them?
1998 Chev Z71
2007 Chev Trailblazer SS
11-03-2009, 03:58 AM
HUMTECH, Can you send me the same file so I have it for future referance, Thanks much, Ed
11-03-2009, 07:54 PM
Rear View Mirror-Driver (Driver Door Module (DDM)-C3)
Connector Part Information
? 6383393-7
? 10-Way F 0.64mm Unsealed AMP (BLU)
Pin
Wire Color
Circuit No.
Function
1-2
Not Used
3
BLK
Driver Mirror Heating Element Low Reference
4
PPL
Mirror Sensor Low Reference
5-6
Not Used
7
GRY
Automatic Day/Night Mirror Signal
8
PNK
Automatic Day/Night Mirror Low Reference
9-10
Not Used
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=11706&refDoc=841408&from=sm# tab20-836113"> Outside Rear View Mirror-Driver (Driver Door Module (DDM)-C4)
? 6383393-5
? 10-Way F 0.64mm Unsealed AMP (BLK)
Pin
Wire Color
Circuit No.
Function
1
YEL
Driver Folding Mirror Motor Extend Control
2
ORN
Mirror Heating Element Supply Voltage
3
RED
Driver Mirror Horizontal Position Sensor Signal
4
DK GRN
5 Volt Reference
5
DK BLU
Driver Mirror Vertical Position Sensor Signal
6
LT BLU
Driver Folding Mirror Motor Retract Control
7
YEL
Driver Mirror Right/Down Motors Common
8
LT BLU
Driver Mirror Motor Right Control
9
LT GRN
Driver Mirror Motor Down Control
10
Not Used
2008
<A href="http://gsi.xw.gm.com/si/cellHandler.do?cellId=164814&refDoc=1968859&from=s m#oth200-1968726"> Door Lock/Window Switch - Driver X3
Pin
Wire
Circuit
Function
1
0.35 L-GN
6160
Outside Left Mirror Vertical Position Control
2
0.35 L-BU
6159
Outside Left Mirror Horizontal Position Control
3
0.8 BK
627
Low Reference
4
0.35 PK
1691
Low Reference
5
Not Used
6
0.35 YE
7197
Outside Left Mirror Drive Motor Common
7
0.8 BK
2267
Mirror Heating Element Control
8
Not Used
9
0.35 GY/BK
1690
10
Not Used__________________
1998 Chev Z71
1998 Chev Z71
11-03-2009, 07:56 PM
2008
2003
1998 Chev Z71
1998 Chev Z71
11-03-2009, 10:05 PM
my brain hurts after looking at this post!
11-07-2009, 02:52 AM
Humtech, i did recieve your pm, thank u. the problem i am having is the wire colors, im trying to figure out what mirror i have now cuz none of the 08 wires seem to be the same,
my 08 mirror should have
GY
D BU
BN
D GN
D GN/WH
WH
D BU/WH
YE
L BU
BK
BK
PK
GY/BL
i have
2 gy none with bk
d bu
bn
d gn
no d gn/wh
no wh
no d bu/wh
ye
l bu
bk
bk
pk
red,lt green, and purple
11-07-2009, 02:56 AM
anyone have any clues, needless to say im a little lost?
11-07-2009, 04:20 AM
GY
D BU
BN
D GN
D GN/WH
WH
D BU/WH
YE
L BU
BK
BK
PK
GY/BL
i have
2 gy none with bk
d bu
bn
d gn
no d gn/wh
no wh
no d bu/wh
ye
l bu
bk
bk
pk
11-07-2009, 03:17 PM
i tried posting all last night but it wasnt working for some reason. i did recieve your pm, thank you, but for some reason quite a few of the wire colors on my 08 mirror do not match up. it has the black and white plugs but i dug into mirror deeper last night and found the mfg sticker, it was made 3/5/07.
the colors i have are
purple
red
dk grn
2 black
2 grey
dk blu
lt blu
lt grn
brn
pink
and the yellow is some sort of common ground i assume, two yellows spliced together about 8 inches from plug.
Seller told me it came from 08 truck, not sure if its true, or not but either way mirror was made in 07, anyone have schematics that match the wire colors i have, im ripping my hair out, thank you
12-08-2009, 03:32 AM
? 6383393-7
Pin
Wire Color
Circuit No.
Function
1-2
Not Used
3
BLK
Driver kool vue mirror
4
PPL
5-6
Not Used
7
GRY
8
PNK
9-10
Not Used
? 6383393-5
Pin
Wire Color
Circuit No.
Function
1
YEL
2
ORN
3
RED
4
DK GRN
5 Volt Reference
5
DK BLU
6
LT BLU
7
YEL
8
LT BLU
9
LT GRN
10
Not Used
2008
Pin
Wire
Circuit
Function
1
0.35 L-GN
6160
2
0.35 L-BU
6159
3
0.8 BK
627
Low Reference
4
0.35 PK
1691
Low Reference
5
Not Used
6
0.35 YE
7197
7
0.8 BK
2267
8
Not Used
9
0.35 GY/BK
1690
10
1998 Chev Z71
Can someone give me a direct link for a procedure about this matter? I think, I messed my setup.
12-18-2009, 07:23 AM
purple
red
dk grn
2 black
2 grey
dk blu
lt blu
lt grn
brn
pink
Did you ever manage to wire the 08 mirrors to your 03 ? I spent some time on mine yesterday ,didn't install yet, but I believe I've figured them out as far as wire color changes. A few simple differences such as , heater wires -08=BK & BK, 03=OG & BK. Fold motor- 08=Gray & Brn , 03=lt.Blu & YEL. And, Yellow turns into white this is a common split spliced to the morror adjust and to the fold. I took the mirror apart ti trace and match all the wires ,then it made sense .athen I spliced my 03 plugs to the 08 mirrors. Harry.
12-18-2009, 06:53 PM
Great info! Let us know if it works after the install.
1994 Chev Suburban Blown
12-20-2009, 06:26 AM
hey guys i couldn`t get the 08 mirror to work with my 03.So i sent it back and got an 06 mirror off ebay.Pluged right in and works fine.
