Old 11-29-2009, 11:09 AM
Hammer Hammer is offline
Hammer is off the scale
Post pulling right when accelerating ? Help.?
Truck pulls right when I accelerate and when I let off the gas it straightens up. This problem is getting worse more I drive the car.
Could a blown steering stabilizer cause such a problem I have the stock stabilizer...
I have rancho lift with cognito upper control arms and 38" tires...
Mike
Old 11-29-2009, 02:44 PM
twr's Avatar
twr twr is offline
Default Re: pulling right when accelerating ? Help.?
hi did you check the front end, idler and pitman arm and tie rod ends, ball joints. If the front stabilizer does not not leak the only way to check it is to remove one end and push it in and out you should feel resistance both ways. I think you will find something other than the front stabilizer is wrong with the truck.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 11-29-2009, 03:44 PM
HumminNBoatin''s Avatar
I would check your steering linkage. Odd's are if you have not yet replaced anything you are overdue. On your stabilizer to test it don't just draw it in and out. Do it with speed and force and see what happens. If you find that when you shove on it real hard and it has a more than a couple inches of travel before the resistance kicks in its worn and should be replaced.
I just got done going through this last month. I ended up doing just about everything. Upper and lower ball joints, pitman and Idler arm, and steering stabilizer.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 11-29-2009, 03:54 PM
twr's Avatar
twr twr is offline
hi i guess i should have add this , If you find that when you shove on it real hard and it has a more than a couple inches of travel before the resistance kicks in its worn and should be replaced.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
