12-26-2009, 05:39 PM
upgrading 08 radio system?
has anyone here upgraded the 08 h2 SUT radio system and still kept the factory radio? i was thinking about adding a amp and changing the speakers out. is there a factory amp currently in the 08 or is it being powered by the radio? is there a factory sub like the 07 earlier models? thanks.
scott j.
2008 h2 sut
2008 escalade
1969 charger
12-31-2009, 01:51 PM
Re: upgrading 08 radio system?
I dont have an 08+ but I do have a 2006 with the factory Bose set up and Navi. I used a PAC interface to add a amplifier to the factory head unit, I hooked up an older 12" Pioneer sub with a Alpine amp (had the stuff sitting in my garage), I also added the Nucleus ipod integration (lets you control the ipod through the factory navi unit). The system sounds amazing, I have a friend who also has an 06 H2 that spent alot of $$ (around 6 grand) having a shop do a full out custom install on his rig and while it sounds good, its not much better than mine sounds (not 6 grand better). Everyone who has heard mine is really amazed at how good it sounds. I did the exact same thing in my Z06 and the result is the same...... 10" Rockford sub in a custom made enclosure (similar to the stealth box) with a Rockford amp, PAC interface and Peripheral ipod2car.
Add just the sub first and see if it satisfies your needs...... if not then you can start adding on. PAC makes all of the neccessary interfaces to add amp(s) to your factory head unit. Good Luck
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
12-31-2009, 11:24 PM
did you still use your bose factory speakers.
scott j.
2008 h2 sut
2008 escalade
1969 charger
01-01-2010, 05:28 PM
Hi Scott, their is a amp in your truck under center consol [UQA] code
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
01-01-2010, 07:14 PM
thanks tracy...is there also a factory sub for the 08 and newer? i know the earlier models had a sub in the ctr console.
scott j.
2008 h2 sut
2008 escalade
1969 charger
01-01-2010, 11:28 PM
hi their is a speaker in there in a h2 i am not sure if its a sub or not, SUT maybe different
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
01-01-2010, 11:53 PM
Hi this if you have a [UQS] code, Amplifier W/premium. This is the one in my truck. I had to tap into 2 wires off it, when i put nav in my truck.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
01-02-2010, 03:07 PM
Yes, still utilizing the factory Bose speakers
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
04-24-2015, 07:43 PM
Hey sorry for bringing up an old thread, but needing to do the same, which lines did you actually tap into for the LOC (line out) and also can you access the rear of the console without needing to pull the whole guts out ?
Cheers
Baldfox
2009 H2 SUV, Trucklite LEDs, Airdoc
06-16-2015, 05:32 PM
bump
Baldfox
